Blown or Fried Crossover
knownalien
knownalien Posts: 143
edited March 2007 in Speakers
How would you know if you had one? Does the speaker hum?
Outlaw 990 PreAmp
Outlaw 7500 5 Channel Amp
Polk LSiC Center
Polk LSi9 FRONTS
LG 42LK520 42" LCD
SONY BDP-S300 Player (Blu-Ray)
Post edited by knownalien on
    F1nut Posts: 51,781
    edited March 2007
    Can you provide more info on what is going on and with which speaker?
  • knownalien
    edited March 2007
    well, I thought that I had a typical ground loop at 60 Hz. Don't ask me how I know it's 60 Hz, I just do. Anywho, I bought a Jensen transformer for $50 which supposedly could fix it, because MUCH of the problem seemed to come from the cable box (has hardrive in it DVR). In other words, if I unplugged the cable coaxial and the problem went away mostly, so the Jensen seemed like a no-brainer. the Outlaw 7500 I use powers all the fronts and bi-amps the LSi15's (the 7500 is a 5 channel 300 watt 4 ohms).I have an outlaw 2200 mono amp that powered the LSi9 rears. The rears never had the hum. Swtiching power sources of the amps never changed anything. The symptom was that when DVD (for example) was selected but no source played, you could put your ear next to the drivers (tweeter too) of all of the fronts and hear the hum. I tried everything I could think of including help from the Outlaw forum:
    http://ubb.outlawaudio.com/ubb/ultimatebb.php?/ubb/get_topic/f/34/t/000987.html
    In the end, I simply used the 2200 mono blocks to power the LSi15's (obviously no bi-amping) and not the only thing you hear out of the LSi15's is a hiss from the tweeter . . . different from a hum. the 7500 is still assigned to the LSiC and the LSi9 rears (where the hum has now emerged).
    The hum is a low level hum which does not increase in volume. My concern is that the "hum" takes away from the accuracy of the music if it is also trying to play this "hum."
    Outlaw 990 PreAmp
    Polk LSiC Center
    Polk LSi9 FRONTS
    LG 42LK520 42" LCD
  • knownalien
    edited March 2007
    But I feel like the culprit is REALLY the cable box. If I unplugg its power cord completly, the sound still exists, but it I unplugg the cloaxial the problem DOES go away. This is why #1 I am baffled the Jensen doesn't work and #2 that somehow the 2200's are doing a better job of "shielding" the channels.
    Outlaw 990 PreAmp
    Polk LSiC Center
    Polk LSi9 FRONTS
    LG 42LK520 42" LCD
  • wirebill
    wirebill Posts: 63
    edited March 2007
    Hello,
    Is your cable connection on the outside of your house grounded to your electrical service? If not, it should be. Just a thought.
    Bill
  • knownalien
    edited March 2007
    wirebill wrote:
    Hello,
    Bill
    I don't believe it is, but it is unclear how this would be. Do you mean the metal rod in my basement should somehow be connected to one of the ground screws on the splitters?
    Outlaw 990 PreAmp
    Polk LSiC Center
    Polk LSi9 FRONTS
    LG 42LK520 42" LCD
  • wirebill
    wirebill Posts: 63
    edited March 2007
    The metal rod that you are talking about is most likely the ground rod.The cable system should be grounded to your electric service. you can run a wire from the cable spliter and connect it to the ground rod clamp.The cable spliter should have a ground screw on it. I don't know that it will solve your hum problem but there is a good chance that it will.
    Good luck,
    Bill
  • knownalien
    edited March 2007
    ^^ I have tried this before, but I admit the connection wasn't very good. I will try this now.
    Outlaw 990 PreAmp
    Polk LSiC Center
    Polk LSi9 FRONTS
    LG 42LK520 42" LCD
  • knownalien
    edited March 2007
    ok. I used the ground wire of cable used for 20 amp sockets. The connections are secure. the hum remains.
    Outlaw 990 PreAmp
    Polk LSiC Center
    Polk LSi9 FRONTS
    LG 42LK520 42" LCD
  • VXR8
    VXR8 Posts: 291
    edited March 2007
    Hi,
    Out of left field but maybe trying something like a Belkin Pure AV product to "filter" out the nasties may help too? Just a suggestion.
    Regards - Gaz from the land of Oz
    Main System
    Denon - AVC-4700H
    Emotiva - XPA-9
    Cambridge Audio - Azur 851C - CXUHD
    Polk Audio - Legend L800 - Legend L400 - Legend L900 - LSiM fx - OWM3
    SVS - PB1000 x 2
    Foxtel - iQ4
    Belkin - Pure AV PF40
    Sony K77A9G
    Front Room System
    PS Audio - Sprout 100
    Cambridge Audio - CXC S2 - CA752BD
    Sony - UBX800 4K BluRay
    Polk Audio - Legend L200
  • knownalien
    edited March 2007
    I already own and use the Monster Ht2000 MKII.
    Outlaw 990 PreAmp
    Polk LSiC Center
    Polk LSi9 FRONTS
    LG 42LK520 42" LCD
  • wirebill
    wirebill Posts: 63
    edited March 2007
    "I already own and use the Monster Ht2000 MKII."
    You may want to try connecting the cable directly into the cable box without going through the monster filter. I have heard of them sometimes creating noise.
    Bill
  • Serendipity
    Serendipity Posts: 6,975
    edited March 2007
    Bill
    Sometimes these things create problems in the signal. Not saying that power conditioners are useless, they have a purpose, but sometimes they can create problems (first hand experience).
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • knownalien
    edited March 2007
    Bill
    it was already set up that way (bypassing the conditioner). in fact, since the run from the monster to the cable box was a short one I decided I wouldn't skimp out on that one and use a Comcast cable (when it originally went through the Monster). So, I went to Tweeter and bought a very expensive one. Would you believe it caused more noise than the Comcast one??!!!! I think I may have a bad cable. Ok, but what gets me is why the mono blocks (2200) seem to be able to handle that better than the 7500 made by the same company (see my sig)???
    Outlaw 990 PreAmp
    Polk LSiC Center
    Polk LSi9 FRONTS
    LG 42LK520 42" LCD
  • wirebill
    wirebill Posts: 63
    edited March 2007
    I think at this point I would try calling the cable company and see if they can help, but I wouldn't count on it.
    I'm running out of ideas.
    Bill
  • adam2434
    adam2434 Posts: 995
    edited March 2007
    Have you tried a 3-prong to 2-prong adapter (cheater plug) for your amps? This approach lifts the earth ground, so do so at your own risk. However, it can reduce ground loop hum significantly though, and is a cheap experiment.
    A combination of this and a cable isolation transformer eliminated 90% of my hum (barely audible).
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • knownalien
    edited March 2007
    that might be an idea. But I just know that Comcast ain't gonna lift a finger to kill a hum. But, I may be able to get them to give me better cable cut to length, because much of the cable I have is too long and therefore wound up, which may aggravating the problem. the 3 to 2 prong apprach may be a last case scenario thing, but I never heard of it before.
    Outlaw 990 PreAmp
    Polk LSiC Center
    Polk LSi9 FRONTS
    LG 42LK520 42" LCD
