Slow Turntable.
riglehart
riglehart Posts: 276
edited July 2007 in 2 Channel Audio
My TT is a JVC LA100 with Ortofon 5 cart I bought in 1984. I used it for several years, then it sat for several. I pulled it out of storage and it had the following issues.
1) It wouldn't start turning unless I gave it a push.
2) Once it started turning, it wasn't spinning at constant RPM. VERY badly.
So, I bought a new belt and that almost fixed the RPM problem. Now it plays a little slow (based on my ear and comparison to the same thing on CD) and I still need to give it a push sometimes. Do I need a new motor, or might it snap out of it after more use? I'm thinking maybe the motor brushes just need to be "shined up" again.
Jolida Tube
Polk 11T, 7, 5, 5jr, 4
Standard equip not worth bragging about.
Post edited by riglehart on
  • hearingimpared
    hearingimpared Posts: 21,136
    edited March 2007
    I had to put two drops of 40 w motor oil on the motor shaft to get my old gal performing correctly.
    I was also told by the manufacturer's customer service that if motor oil doesn't work, use a good 3 in 1 oil, if that fails, use WD 40 with the little red straw and shoot some down into the motor spindle base. . . luckily the motor oil worked.
  • angf117
    angf117 Posts: 1
    edited July 2007
    do either of you have an owners manual? i also have this turntable but i lost my manual a long time ago and need to set the tracking...can you help?
    thanks,
    ric:D
  • engtaz
    engtaz Posts: 7,669
    edited July 2007
    +1 hearingimpared
    Dust or dirt or luberacant has dried up. Good Luck and hearingimpared is the vinyl guy hear, at least to me.
    engtaz
