amp price
vawakemonster
what would you pay for a pheonix gold amp with the following spec's:
2 x 50 Watts per channel Bridgeable Outputs
Tri-Linear output capability, simultaneous stereo & bridged mono Adjustable Bass EQ (0 to +12db) @ 45Hz
Pulse Width Modulated MOSFET Switching Power Supply Stable into 1 Ohm loads
High-current Triple-Darlington Output design 2 layer, 2 ounce Gold Plated Copper G-10 Glass-Epoxy printed circuit board
Variable input sensitivity (200mV to 2V) Thermal Overload Protection
Superior muting circuitry assures no turn / turn off noise Optically isloated power supply
VI limited circuitry with overcurrent LED Extensive burn-in and QC testing for the ultimate in reliability
Specifications
Output power per channel Into 4ohm @ 12V DC - 50 WRMS
Into 2ohm @ 12V DC - 100 WRMS
Bridged power in to 4 ohm - 200 WRMS
THD at rated power 4ohm 0.02%
SMPTE at rated power 4ohm 0.05%
Frequency Response 10Hz to 30Khz +/- 1db
Signal to noise ratio 100db (20 tp 20KHz)
Input Sensitivity 200mV to 2V
Current consumption @ 4ohm stereo - 15A
@ 2ohm stereo - 30A
@ 2ohm stereo, 4ohm mono - 35A
Efficiency > 80% (Power supply)
Dimensions 10.625inches Length x 8.25inches Width x 2.0 inches Height
Specifications
@ 2ohm stereo - 30A
Dodge Dakota
HU: Pioneer
Amp: Profile AP600 & Phoenix gold r2.5:2
Speakers: Boston SX 6.5 components
Subwoofer: polk mm2104
HU: Pioneer
Post edited by vawakemonster on
5 bucks...!
did I win ?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
