Matching AVR RTi 10
sudhirsh
I have recently purchased RTi 10/FXi3/PSW404/CSI3 and going to use it with Onkyo 804. Is anybody using this combination? as per technical details of both there should not be any problem.
Post edited by sudhirsh on
matching help
I'm using a very similar setup, I have the Rti10's, CSi5, FXi5, and a velodyne dps12 subwoofer. I'm using the Onkyo 803, and everything sounds good in my room!
However, I still have been debating on buying a seperate amp to see if I could tell a huge difference with the extra power to the rti10's. You should like your setup. -
I have same setup but with RTI12 's added a earthquake cinenova7 and now the more I raise the volume the better they sound big difference cristal clear soundHome Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
2 Channel rig Sunfire grand cinema 5ch,sunfire TGA III,Rotel 1072,polk RTI12,Monster hts 5100 -
crd2002 wrote:I have same setup but with RTI12 's added a earthquake cinenova7 and now the more I raise the volume the better they sound big difference cristal clear sound
Are you biamping your 12s or just running them off your power amp?Shoot the jumper.....................BALLIN.............!!!!!
I run all speakers from the amp only nothing from the onkyoHome Theater sony 52 inch lcd,Cinenova grande 7 channel, polk RTI8,CSI5,FXI5,onkyo 805
I'm close to that setup...804, Rti8s, CSi3, old surrounds for now. From what I've read, Onkyo amp fans will tell you they're a good match for Polk speakers.
bringit167 wrote: »I'm using a very similar setup, I have the Rti10's, CSi5, FXi5, and a velodyne dps12 subwoofer. I'm using the Onkyo 803, and everything sounds good in my room!
I'm running almost the same setup but with the Velodyne DLSR-15 Sub and the Pioneer Elite VSX72-TXV receiver. It replaced an older Onkyo and really opened up the Polk's.
