problems with Denon DVM-7155
AdamRagland
Hey i have a Denon DVM-7155 dvd player/changer. I have run into a few issues with it. It is taking an extremely long time loading a dvd (between 30s-1minute) and it also will not play ANY duplicated discs. (in other words if it isn't a commercially replicated disc, it wont load. It says there is a problem with the disc. Any ideas on what the problem might be?
Post edited by AdamRagland on
how old is the player? my denon cd changer, which is probably about 10 years old has recently stopped playing any duplicated discs. after asking around, i was told it is probably the laser, which definately wears out with age. as the laser wears, burned discs will be the first to go. not sure about the long loading time on dvd's though.
is that something that is worth replacing or just get new unit?
