Help me choose a system!
AngryPenguin309
AngryPenguin309 Posts: 9
edited March 2007 in 2 Channel Audio
I am very new to the speaker scene, right now I have a $35 Creative 2.1 set for my computer, but I would like to upgrade to something a bit better. Can anybody help me choose the right system?
My room is pretty small, and my budget is $1,500.
Post edited by AngryPenguin309 on
  • cmy330go
    cmy330go Posts: 2,341
    edited March 2007
    You're going to have to give us more to go on than that.
    Satellite, bookshelf, or floorstanders?
    Any existing gear?
    Is the budget for just speakers or speakers and electronics.
    Here is one tip that always applies: If you can, go to a local audio shop to audition speakers. In the end it only matters what sounds best to you.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • AngryPenguin309
    edited March 2007
    I don't have much room for floorstanding, although I could put them behind my desk (which would probably obstruct a lot of the sound) so I'm guessing bookshelf would be the way to go. I have a nice big desk that is pretty much 180 degrees around me
    I have no existing gear, just a computer.
  • ledhed
    ledhed Posts: 1,088
    edited March 2007
    Do you want to use your computer as a source?
    Are you ok buying used?
    God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
  • AngryPenguin309
    edited March 2007
    No, no used. Only new. Yeah, I want to use my computer as a source
  • ledhed
    ledhed Posts: 1,088
    edited March 2007
    Well, not buying used will eat up your budget but, 1500 is still a decent amount. What is the quality of your digital audio files? It is really a must to rip at least in some form of lossless. The best option would be an outboard DAC and an optical out on the soundcard. But, if you want to save money for the amp and pre-amp then M-audio makes some really nice soundcards.
    http://www.zzounds.com/item--MDOAP192
    http://www.zzounds.com/item--MDOAP2496
  • liordra
    liordra Posts: 152
    edited March 2007
    a funny thing .... while I'm knee deep in sound card research I found a post mentioning one of my prime candidates http://www.zzounds.com/item--MDOAP192
    .... if you have any experience with it ... will it get the work done when connected to Head Phones (senn 580) ?
    my internet research so far has been inconclusive.
    I do most of my listening with a head piece in front of my computer.
    10x
  • cstpeter
    cstpeter Posts: 387
    edited March 2007
    Angry Penguin, are you looking for 2-channel only or do you plan on eventually expanding to surround?
    Von Schweikert VR4-jr
    Valve Audio Predator
    Denon DVD-2900
    PS Audio Digital Link III w/Cullen Level IV Mods
    Pro-Ject Xpression w/Blue Point No. 2
    Graham Slee Special Edition 2
    PS Audio UPC-200
  • AngryPenguin309
    edited March 2007
    I am just looking at 2-channel audio, not planning on expanding to surround.
    Is the sound card essential to the system? Right now I use the built-in soundcard on my motherboard
  • ledhed
    ledhed Posts: 1,088
    edited March 2007
    If you already have a digital out (coaxial or optical) then it is not super important, you will just need a DAC to get the most out of it. If you don't want to spend much on the computer part then get one of the M-Audio boards.
    It is important - it is just like a $50 dollar DVD player being used as a CD player compared to a $200 + dollar CD player.
    Liodra - I don't have any experience but for a nice headphone system you need a headphone amp. Nice ones can be had for under $300
  • AngryPenguin309
    edited March 2007
    Alright, I see. Suppose I get the following parts -
    http://www.onecall.com/ProductDetails.aspx?id=28531
    2 x http://www.polkaudio.com/homeaudio/products/rti6/
    http://reviews.cnet.com/Harman_Kardon_HK_3480/4505-6466_7-30920363.html
    Would I get good sound?
    Sorry, I know little about audio and such and just want a good sound system
  • ledhed
    ledhed Posts: 1,088
    edited March 2007
    Yes, I would think you could get good sound though Polk is not known for its subs (and I don't know who makes a nice budget compact one, someone here will though) So, 180 for the card and roughly 350 for the speakers. that still leaves you roughly $1000 and you could definitely get into separate Amp/preamp for that money.
    With a small room, wpc is not a huge consideration because it won't take much to fill up a small room. I'm sorry but I have no clue what new equipment is in that price range as I only look at used. If you do warm up to used, for 1K you could get a Parasound HALO P3 preamp and A23 amp which I guarantee you will kick that HK all the way to China
    http://www.parasound.com/halo/
  • AngryPenguin309
    edited March 2007
    My room is pretty small, i don't need much to fill it with sound.
    You can bi-wire the speakers right? Will the HK allow me to do that?
  • ledhed
    ledhed Posts: 1,088
    edited March 2007
    I don't know a whole lot about Bi-wiring but there really isn't much of a point unless you are using two separate amplifiers as I understand it.
    Many others here can recommend very nice separates that will not break the bank yet give you nice clean sound that the HK just can't compete with.
  • cstpeter
    cstpeter Posts: 387
    edited March 2007
    Angry P., looks like you're on the right track. The system you listed will definitely provide good sound. But don't stop there! Go out and audition as many speakers in your price range as possible. RTi6 and Harman/Kardon receivers are sold all over, so you should be able to get an ear on the stuff before you purchase.
    Denon DVD-2900
    PS Audio UPC-200
  • janmike
    janmike Posts: 6,146
    edited March 2007
    Bi-wiring is a speaker thing. Check to see if that can be done on the speakers and not the amp.
    Michael ;)
    NORTH of 60°
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited March 2007
    I can't help your computer question but gotta love your S/N.
    waaaaaaaaaaaaaaaaaaaaaaaaaaaa AngryPenguin:D
    RT1
  • AngryPenguin309
    edited March 2007
    Thanks for the help everyone!! I think I got the idea
  • janmike
    edited March 2007
    So AngryPengiun, tell us about the name. Being from Canada I think Hockey right away (Pittsburgh Pengiuns).
    Michael ;)
    NORTH of 60°
  • schwarcw
    schwarcw Posts: 7,358
    edited March 2007
    janmike wrote:
    So AngryPengiun, tell us about the name. I think Hockey right away (Pittsburgh Pengiuns).
    Me TOO!:D :D
    Carl
  • AngryPenguin309
    edited March 2007
    To be honest, with all the attention monkeys are getting nowadays (ever since Dane Cook released the bit about loving monkeys. Damn him.) I got pretty upset because God in heaven knows penguins are cooler and would kick monkey **** nine out of ten times.
    Maybe even ten out of ten.
    So that's how I came to this screen name :p
  • janmike
    edited March 2007
    Looks like the Pens are staying.
    Pens Staying in Pittsburg
    Michael ;)
    NORTH of 60°
