Will the Amp and Sub match...?
zoso02
Hi, I currently have a MTX 5512(300W RMS) running off a Alpine MRD M605 (Mono - 600W RMS @ 2Ohm @ 14.4V). I was looking at getting the Polk Audio SR124 sub (700 W RMS); would I be underpowering it if I were to use the same Alpine monoblock? Do you think it's ok to get a sub that is 100W higher than what the amp can provide? I just changed my speakers to Polk (MMC 6500 and MMC 690)...quite impressed; was wondering if their Sub (SR124) sounds as good? Also, any other suggestions for a sub that will go well with my Amp...better SQ and SPL than the 5512 Thanks...
Post edited by zoso02 on
That amp will work fine with the SR sub.
It will provide enough power to push the sub well and so long as you dont over crank the volume and gain, it wont hurt anything.polkaudio sound quality competitor since 2005
Thanks...do you think it's a good sub? Any others that you would recommend...that would match my amp?
Help!!
i have seen sound splinter recamended a lot, but there site has been down the last few days.Polk monitor 10B's and 5 jr's
Adcom gfa 5500 and HK/240
Adcom gtp 400
Adcom gcp 600
MusicHall MMF 2.1 TT -
I think that you could still get in contact with Mike, the owner.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin
