Multiple subs to sub out on receiver?
Face
Face Posts: 14,340
Is it ok for 2 or even 3 subs to share the same sub output on the back of a receiver?
Thanks!
Post edited by Face on
  • Serendipity
    Serendipity Posts: 6,975
    edited March 2007
    It should be fine.
    I did some calculations a while ago, and it would take 16 subs connected to the sub out on the back of my AVR to overload the output.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited March 2007
    if you have small rears, and a small center, you could run 2 subs up front, on of the lfe, and the other off the center, and then run the other sub off the rear channels. Or run one for you left channel, on for right , and one off the lfe. Play around see what you like. Before I got my denon I ran my sub off the center channel with the lfe switched off, and my l/c/r all as large.
  • Face
    Face Posts: 14,340
    edited March 2007
    Even though I have small speakers up front, when I switch to large on the receiver, it sounds better. Since the 3rd sub I'm receiving matches one of the other two, I can use that pair up front(L&R) and the third off the LFE or center possibly. Thanks for the help, my neighbors are going to hate me soon. :)
  • Eric W
    Eric W Posts: 556
    edited March 2007
    2-3 should be fine if using a Y splitter from "sub out". It will depends on the input impedance of the sub as well as the sub output's capability on the receiver.
    -Eric
    -Polk Audio
