problem with 1.2tl's no interconnect
marcusmy2k
hi i have a set of srs1.2tl's and i am running a pair of carver silver 9t monoblock amplifiers to them. i had tried to plug in the interconnect and it sounded like the world was coming to an end. so i am running these speakers without the interconnect cable. it seems like all the drivers and tweeters are working? does anyone know what part of the speaker i am not utilizing wothout the cable connected? i have received the plans from polk on how to build the AI-1 cable but i am just wondering?
Post edited by marcusmy2k on
You have to use the A1 interconnect with your setup. and the part you arent using is the difference in signal from right to left ( part of the SDA portion) but all drivers should be working.:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
marcusmy2k wrote:hi i have a set of srs1.2tl's and i am running a pair of carver silver 9t monoblock amplifiers to them. i had tried to plug in the interconnect and it sounded like the world was coming to an end. so i am running these speakers without the interconnect cable. it seems like all the drivers and tweeters are working? does anyone know what part of the speaker i am not utilizing wothout the cable connected? i have received the plans from polk on how to build the AI-1 cable but i am just wondering?
You must use common ground amplifiers for the SDAs that seems to be the problem here. You need to strap the negative speaker terminals of the mono blocks together to make them common ground. I had to strap the negative speaker terminals of my Adcom 565 mono blocks together as well as strap the chasis together.
Do this instead of using a AI-1 cable. The AI-1 is a work around and degrades the sound.
I have uploaded a pdf which is a memo from Polk about your exact amp. You may want to check with Carver also to find out if it is okay to strap the chasis of the mono blocks together. This may be necessary to avoid a ground loop hum. -
1. You are NOT using half of the drivers, the SDA drivers in particular.
2. Before strapping the negative terminals, you'd better be damn sure you can do that with those amps as that doesn't always work. The PDF addresses the Silver 7t's, not the 9t's.
3. The factory AI-1 is NOT a work around and has never degraded the sound in my experiences.
4. When building the AI-1, do not use the Stancor transformer as it does degrade the sound. Instead, use the Avel transformer.Political Correctness'.........defined
President of Club Polk -
HI- Where did you find that memo? I've not been able to find anything regarding the intelligence of doing something similar to my Carver M500. Not that big a deal, of course, just biding time 'til I pony up and buy an Avel.Wristwatch--->Crisco
F1nut wrote:1. You are NOT using half of the drivers, the SDA drivers in particular.
I wasn't speaking from experience here about the AI-1 degrading the sound, I was going by threads that I have read when looking to make my 1.2 tls the best they can be, if F1nut says it doesn't degrade the sound from his experience then go by that.
Jess are you sure the AI-1 isn't a work around for SDAs to work with non-common ground amps? -
strider wrote:HI- Where did you find that memo? I've not been able to find anything regarding the intelligence of doing something similar to my Carver M500. Not that big a deal, of course, just biding time 'til I pony up and buy an Avel.
I believe Darqueknight sent it to me. If it wasn't Darqueknight it was another forum member that took it from the Polk website. -
Joe, I certainly don't consider it a work around. I call it a blessing.Political Correctness'.........defined
F1nut wrote:Joe, I certainly don't consider it a work around. I call it a blessing.
Good enough for me! -
thanks for all the help. i am going to contact sunfire and see what they think about running the 2 grounds together on the 9t's oh does anyone know what the difference between the 6503 driver and the 6502?
Performance wise, everything, not even close.Political Correctness'.........defined
