my xlr cable problem
dholmes
dholmes Posts: 1,136
I recently sent back to Bettercable a set of xlr cables thinking that there is something wrong with them.I had 3 different amps that where defective,hum-buzz so loud that it hurt your ears. Now I have a Ati 3007 amp & its great,Im using rca cable since the xlr cables are being looked at by Bettercables.If they tell me the cables are okay should I be affraid to use them? Could the 3 amps been defective or was it the xlr cables? Bettercables said that they had never heard of there cables or any other brand causing that kind of a problem.What do all of you think? thanks didnt mean to be so long winded.
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
  • scooter80
    scooter80 Posts: 39
    edited March 2007
    I would think that three amps being "defective" is a whole lot less likely than the cables being bad. All it takes is a little shred or a single strand of shielding contacting the conductor and you'll get hum or interference of some sort. Defects can happen in anything, but in three things in a row?
  • dorokusai
    dorokusai Posts: 25,627
    edited March 2007
    I recently had one of my MIT cables develop a short at the termination, from average use. I've heard of many Audioquest cables with issues so it's certainly within the realm of possibility.
    I concur with Scooter, that's HIGHLY unlikely.
  • dholmes
    edited March 2007
