speaker mounts
uroblast
uroblast Posts: 1
edited March 2007 in Speakers
This should be an easy question. I just purchased Atrium 45 In/Out speakers from a Polk certified on-line dealer. The speakers arrived with the included mounting brackets but only had one of the screw-in devices that secure the speaker to the bracket. I only got one per speaker. I have not been able to find out if this is all that is supposed to be included or if I am missing 2 screws. There is certainly a threaded opening that has nothing to secure the speaker on one end. Thanks for responses.
Post edited by uroblast on
  • cmy330go
    cmy330go Posts: 2,341
    edited March 2007
    Just click on the contact icon at the top right corner of this webpage to get a hold of customer service. They'll be able to help you.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
