Split signal from Yamaha to seperate amps
MillerLiteScott
MillerLiteScott Posts: 2,561
edited March 2007 in 2 Channel Audio
I have 2 Female RCA > 2 male splitters
Can I use those to split the signal of my L/R to go to my 5 channel amp for HT and the other to my ASL mono blocks and leave them connected and just turn on which ever amp(s) I want to listen to?
Will this hurt anything or cause signal degradation on a level that would impact my modest system?
Scott
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Post edited by MillerLiteScott on
    VR3 Posts: 28,774
    edited March 2007
    I did this once.
    In short it just does not work. Period - little to no sound.
  • riglehart
    riglehart Posts: 276
    edited March 2007
    I've done this and it worked fine. What you suggest won't hurt anything. However your results may vary. Some audiophiles with golden ears may gasp, though.
    Try it with the splitters, then moving the cables back and forth. You decide. You can always try an expensive pair of splitters, as apposed to the $3 radio shack ones. If you do, let us know the results.
    Jolida Tube
    Polk 11T, 7, 5, 5jr, 4
    Standard equip not worth bragging about.
  • dorokusai
    dorokusai Posts: 25,577
    edited March 2007
    Yes, it depends on the GAIN of the pre-amp in the output stage in regards to volume....it may or may not work well.
  • MillerLiteScott
    edited March 2007
    I have decent quality splitters AQ Copperhead. I tried just hooking my Yamaha up to my ASL and I had a decent hum which drove me crazy and it sound quality was pretty harsh, which I think is either my AVR or my DVD.
    I decided to just listen to my computer directly connected to the ASL and Monitor 5's and it was awesome. I am getting a huge sound stage @ 10-12 feet wide with instruments (mostly guitars) beyond and in front. Main vocals in the center with bass below the vocals, at times the back up vocal seemed to nearly wrap around to my listening position.
    I listened to music from 7:30-11:30 last night all at 90+ db's.
    I listened to the whole album or nearly the whole album of Train, Beatles One album, Eric Clapton, Dada, The Clarks, Bob Marley, Counting Crows and The Connels.
