yet anther: help me setup my sub question
Hey all,
Take a look at my sig. Any suggestions on what settings would be a good start for both my fronts (large or small; ive heard conflicting things here) and what level to set my crossover at.
Any and all feedback is welcome...
Rec: Yamaha RX-V659
L/R: Polk Audio RTi8's
C: CSi3
RSurrounds: TC610i's
Sub: Hsu Research STF-2
Showcase:
http://www.polkaudio.com/forums/showcase/view.php?userid=78895
Post edited by Jet_olson on
  • ben62670
    ben62670 Posts: 15,969
    edited March 2007
    Manually set them to 80hz hp and lp.
    Your speaks are rated for about 50 on the low end. If you like the boom effect you can set the sub as high as 120
    Enjoy
    Ben
  • Jet_olson
    Jet_olson Posts: 39
    edited March 2007
    Awesome Ben..thanks!!!!
    Rec: Yamaha RX-V659
    C: CSi3
    Showcase:
  • Schwingding
    Schwingding Posts: 363
    edited March 2007
    Set them to small, set the crossover to 80Hz. See if you like it. If not, move the crossover up or down till you are happy.
    Check your sub's high pass rolloff - if the sub start to roll off from 60 and you have your xover to 80 you may have a dip in response between the two. I had to move mine away from 80 because there was a huge SPIKE in the response at 80Hz. Still can't exactly figure out why, but dropping it to 60 fixed it.
    Generally accepted is that you can start to localize sounds at around 100Hz, so if you set your crossover there, you may actually begin to hear where your lows are coming from rather than having them sound like they're coming a some uniform direction as with the real low freqs.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
  • Jet_olson
    Jet_olson Posts: 39
    edited March 2007
    thanks Schwing....I cant wait...it was suppose to come today but I still dont have it....I'll let ya all know when I get it.
    Rec: Yamaha RX-V659
    C: CSi3
    Showcase:
  • Jet_olson
    Jet_olson Posts: 39
    edited March 2007
    Alright I finally got my sub and I am confused...I setup my sub to have its crossover off and put my volume at about 75%. I ran my auto setup for my amp and it set its crossover to 160 (which I thought was high especially considering my fronts) and my subs output seemed low from a volume perspective...I also thought with my RTi8's that I could easily have my crossover set below 90.
    It probably sounds crazy but when I left my receivers crossover at 160 and then turned on my subs crossover to 90..the output was much better and sounded more robust for music and movies. Now the million dollar question is that if my receiver's crossover is set to 160 and my subs crossover (im thinking im traveling into dangerous territory here) is set to 90 that I will be missing some range between 160 and 90? Or is that not the case?
    P.S. for my receiver I could not set the crossover to off..it only goes down to 40...havent figured out how to turn it off yet.
    ...any ideas here?
    Rec: Yamaha RX-V659
    C: CSi3
    Showcase:
  • Ern Dog
    Ern Dog Posts: 2,237
    edited March 2007
    ...any ideas here?
    As an experiment put on some bassy music then unplugged your front speakers so that you're just hearing the sub output. First listen to it using the subs internal crossover on and the avr crossover off. Then switch and turn the subs crossover off and use the avr crossover and see which sounds better. Play around with different crossover points. I noticed that using the subs crossover and the avr crossover off- bass sounded tighter, more extension and more impactful.
    Using the avr auto set up is fine to start with, but ultimately you have to tweak it to where it sounds the best. I've got my sub crossover set to 40hz. It also helps to have an Avia calibration disk and SPL meter because it is more accurate than your ears. Sub placement is also key.
  • Ron Temple
    Ron Temple Posts: 3,212
    edited March 2007
    Ypao and other auto eq programs do funny things with speaker size, distance and crossovers. You should go back and manually set all speakers to small and the crossover to 80. Then go back and disable or turn the crossover on the sub all the way up.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
