Upgrading RTi8 to RTi12 - keep or sell the 8's?
Current setup has RTi8's as front left/right and 4 RTi6's for the surrounds. When I upgrade the fronts to RTi12, would you move the RTi8's to left and right surround or keep the surrounds as all RTi6 and sell the 8's?
I'm leaning towards keeping all 6's for surrounds as that way they all exactly match and there's not much low end in the surround channels anyway.
On the other hand, 8's as SL and SR would still closely match the 6's as SBL and SBR and there's a bit of a cool factor in having towers in the back. Plus I'm having a hard time with the idea of selling the bigger speakers and keeping smaller ones (no logical but it still there!)
Opinions?
Opinions?
No earth robot is going to tell ME which button to press!!
--Stuff--
Front: Polk Audio RTi12
Center: Polk Audio CSi5
Surrounds: Polk Audio RTi8 (x4)
Sub: SVS PB10-ISD (Dual)
AVR: Denon AVR-3805
Blu-Ray: Panasonic BD30
Display: Sony KDL-55NX720B
STB: Xfinity X1DVR
--Stuff--
AVR: Denon AVR-3805
STB: Xfinity X1DVR
Post edited by cnjvh on
I suggest putting the 8's in the back.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
DITTO ON THAT Early.
You will really appreciate having those 8's in the rear. Especially if you ever get into multichannel music.
The best of all worlds (IMO) in HT and MC music is having the exact same speakers all the way around, but most people don't have space for towers in the rear, so compromises are made for placement considerations. With the 8's in the rear you'll be closer to that ideal than with the FX speakers.
Put them there, see if you like it. If not you can always sell them later. Would be a shame to not even try it if you have the space.HT/music rig
Panasonic PX60U 50" plasma
Yamaha 5990 AVR
Onix SP3 tube amp
bunch of Outlaw 2200 monoblocks
DUAL SVS PB12+/2 subs :eek:
Denon 3910 DVD/SACD/DVD-A
DirecTV HR10-250 DVR
Onix Strata Mini mains
Mirage OM10 surrounds
Polk CSi5 center
Polk SC80 rear surrounds
Samsung BDP1000 blu-ray player
Bedroom rig
Jolida SJ302a tube amp
Denon 2910 universal player
Onix Ref 1 monitors
Velodyne minivee -
I always have a hard time selling speakers, especially when i know im not going to get what i paid for them. My solution is to take the 6's or 8's and put them in another room. I have my 6's hooked up to my computer.Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture. -
Ok, looks like I'll start with the 8's in the back L/R and put the 6's in the closet for a bit and see what I think. 6's are small, maybe I won't sell them at all...just store em until I need a bedroom setup or something...No earth robot is going to tell ME which button to press!!
--Stuff--
AVR: Denon AVR-3805
STB: Xfinity X1DVR -
Keep both. Maybe you'll go 7.1 someday. Either way, the spare pair can and should be used for a 2nd room setup.
I say move the 8s to the surround duty.
cnjvh wrote:Ok, looks like I'll start with the 8's in the back L/R and put the 6's in the closet for a bit and see what I think. 6's are small, maybe I won't sell them at all...just store em until I need a bedroom setup or something...
I just noticed that you dont have an amp. Is that correct? I have demoed that entire line with only a receiver (speakers crossed over at 60hz) and the 6's sound better than the 8's, which sound better than the 12s. Now when you add an amp to the system, I'm sure it will be the exact opposite.Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
dane_peterson wrote:Keep both. Maybe you'll go 7.1 someday. Either way, the spare pair can and should be used for a 2nd room setup.
Just to clarify, I already am at 7.1 with (4) 6's currently handling the surround duty. The new setup would be either:
(2) 8's and (2) 6's with the 8's at SL and SR and the 6's at SBL and and SBR
OR
(4) 6's remaining at SL, SBL, SBR, and SR.No earth robot is going to tell ME which button to press!!
--Stuff--
AVR: Denon AVR-3805
sickicw wrote:I just noticed that you dont have an amp. Is that correct? I have demoed that entire line with only a receiver (speakers crossed over at 60hz) and the 6's sound better than the 8's, which sound better than the 12s. Now when you add an amp to the system, I'm sure it will be the exact opposite.
That is correct - no amp. Just the Denon 3805. So you found with no amp the 6's were best, followed by the 8's and then the 12's?
Interesting...may be looking at an amp now.No earth robot is going to tell ME which button to press!!
--Stuff--
AVR: Denon AVR-3805
cnjvh wrote:Just to clarify, I already am at 7.1 with (4) 6's currently handling the surround duty. The new setup would be either:
OR
M'bad. Wasn't totally paying attention. I would agree, you'll definitely want an amplifier. Your receiver won't be able to power all those appropriately. -
cnjvh wrote:So you found with no amp the 6's were best, followed by the 8's and then the 12's?
yea, but I didnt compare the 8 and 12 very much. The 6's just sounded so much better with the receiver (there is only 1 woofer in a 6).Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
I definitely agree with moving the 8s to surround duty, especially if you like multi-channel music. I have a Denon 2807 and my 6s sound good off it's 110WPC, but my 8s off the amps sound much better. I would think the 12s would be a lot more power hungry than the 8s.
At some point I was hoping to upgrade my fronts and have 8s for surround and surround back, maybe then I'll go with the 12s.ncmarine
60" Sony SXRD
Denon AVR-2807
Adcom GFA 555Mk-II
Outlaw M2200 x 3
Fronts - RTi8s
Center - CSi5
Sides - Rti8s
Rears - RTi6s
Sub - PSW505
DVD - Samsung HD860
Playstation 3
XBox 360
Monster HTS2600 -
I use the old bother line of RTi12 the RTi150 for Fronts, with the older bother of those RTi8 the RT800i for back surrounds I like the sound of them and I like the look of them. And may add its a WOW factor when someone sees it for the first time.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I like the wow factor :-)No earth robot is going to tell ME which button to press!!
--Stuff--
AVR: Denon AVR-3805
STB: Xfinity X1DVR
