Auto on and off feature problems.
louthewiz
I am running 3 amps with my avr and one of them got fried,so I purchased another one to replace the fried amp for my center at 200wpc , but it has no auto on and off feature and no 12volt trigger so I really don't want to plug it into the switched outlet on my avr since it's rated at only 100watts and I don't want to leave the amp on all the time.
So my question is is there some type of gadget I can get to turn my amp on and off automatically.
My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool:
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
Post edited by louthewiz on
You could try something like this:
http://www.smarthomeusa.com/ShopByManufacturer/Bits-Ltd./Item/SCG5/manual/
I built my own years ago with a plain power strip, and a relay purchased at Radio Shack. The unit was switched on and off by the switched outlet on the pre-amp. -
Can you provide a schematic or drawing since I am pretty handy with a soldering iron.My gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
You will need these:
http://www.radioshack.com/product/index.jsp?productId=2049722&cp=&sr=1&origkw=relay&kw=relay&parentPage=search
http://www.radioshack.com/product/index.jsp?productId=2062476&cp=&sr=1&origkw=relay+mount&kw=relay+mount&parentPage=search
And a power strip with space to mount them, and a spare two prong ac plug with wire (old lamp cord or whatever).
The schematic is on the relay package.
Cost is about $20 total, if it were available at the time, I would have just bought somthing pre-made, like the one in the above link. -
I already made one by using a mini 9 volt relay with a 12a 120v contacts and a $3.99 power strip a 9 volt plug in transformer a soldering iron and a hot glue gun and she works great.
Thankyou for the info....My gear,
Acer PH530 720P PJ
Yamaha HTR 5790
Toshiba HD-A3
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
polk cs400 center
polk RT400 mains
Velodyne DPS-10 sub
