Opinions for HT set up needed
Here is what I have and what I plan to do:
Placement/Spearkers
Receiver: Yamaha RXV2500
Fronts: RT800i
Center: CSi40
Surrounds: RC85i
TBD: RTi4
Wiring: 14 GA Monster (bi-wiring the RT800i)
I have build a nice-looking floating shelf for the components and the 42" Samsung LCD. The center will be mounted (also a floating look) under the shelf (approx. 30" from the floor). The RT800i's will be an equitable spacing of course.
I plan to mount the RC85i's as rear surrounds in the ceiling about 1' behind the main seating area. Thoughts?
Not sure what to do with the RTi4's. I am thinking of mounting them on the wall a few feet above the RT towers (they seem to give a nice compliment to them). Or should I mount them some where behind the seating area (not sure where). Thoughts?
Any help/guidence would be much appreciated.
Thanks!
Placement/Spearkers
Fronts: RT800i
Center: CSi40
Surrounds: RC85i
TBD: RTi4
Thanks!
I friggin' rock. I really, really do.
Never confuse post count with wealth of knowledge.
Post edited by ffej0872 on
Nothing?I friggin' rock. I really, really do.
Never confuse post count with wealth of knowledge. -
Patience ffej0872. A little more info wouldn't hurt, room size,etc. I believe the receiver is 7.1 so you may want to use them as the sides or rears. You will find that the folks here have a wealth of knowledge and have helped me tremendously but you can't expect replies quickly all the time. The "nothing" reply doesn't help either. Just relax and play nice and you'll get replies.
daboyz wrote:Patience ffej0872. A little more info wouldn't hurt, room size,etc. I believe the receiver is 7.1 so you may want to use them as the sides or rears. You will find that the folks here have a wealth of knowledge and have helped me tremendously but you can't expect replies quickly all the time. The "nothing" reply doesn't help either. Just relax and play nice and you'll get replies.
Great. Thanks for the advice. And thanks for killing my thread.I friggin' rock. I really, really do.
ffej0872 wrote:And thanks for killing my thread.
Come Again? -
Not sure how I killed it, but if I did, RIP.
daboyz wrote:Not sure how I killed it, but if I did, RIP.
I'd have to say, I didn't think this type of forum would have the failings you typically find with the run-of-the-mill, good-for-nothing message boards but I guessed wrong. There you will find people who jump the gun and jack threads because they misinterpret a post (even there they know a follow-up post that reads "nothing?" is nothing more than a "bump" to send your post to the top for more exposure not thowing down the gauntlet). Relax boys, you can have your ivory towers and your playground back. I'll look elsewhere for y information. You make Polk proud I'm' sure.I friggin' rock. I really, really do.
I don't understand/recommend using both inwalls and bookshelves unless the room placement calls for it. I would decide which I preferred and match the sides/surrounds with the rears. Personally, I find Polks inwalls to be the lesser performing or a compromise unless you go for their best line that matches the LSi lineup well.
I've always felt that a great 5 channel setup beats an average 7 channel everytime.
Welcome to CP, and stick around and let us know how it all turns out for you.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
ffej0872 wrote:Great. Thanks for the advice. And thanks for killing my thread.
Dennis Gardner wrote:
I've always felt that a great 5 channel setup beats an average 7 channel everytime.Testing
Testing
Testing -
It's easy to misinterpret tone etc. on a forum. I'm sure the OP and the rest of us can let this meaningless argument go.
Sorry, I can't help you since I have zero knowledge of in-walls. I just wanted to see if we can get you some help with your audio situation and forget the other stuff.
Happy thoughts all! -
Dennis Gardner wrote:I've always felt that a great 5 channel setup beats an average 7 channel everytime.
Yes, but a great 7 channel system beats a great 5 channel every time.
Uggh... did I ruin this thread too?Holydoc (Home Theatre Lover)
__________________________________________
Panasonic -50PX600U 50" Plasma
Onkyo -TX-NR901 Receiver
Oppo -Oppo 980HD Universal DVD Player
Outlaw -770 (7x200watt) Amplifier
PolkAudio - RTi12 (Left and Right)
PolkAudio - CSi5 (Center)
PolkAudio - FXi3 (Back and Surround)
SVS - PB-12/Plus (Subwoofer)
Bluejean Cables - Interconnects
Logitech Harmony 880 - Remote
