How to thread reel to reel?
gwh
gwh Posts: 1,451
edited February 2007 in Electronics
How in the hell do you thread one of these things?
looking for a step by step website with pics.
Thanks,
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Post edited by gwh on
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Without knowing your gear......................With the feed reel on the left and takeup/empty reel on the right, the tape should come off the outside of the left reel and feed to the outside of the right reel. The reels move counterclockwise when in play mode.
    The tape should simply slide against the heads/rollers from the underside of the head area. This should be done when player is not in play mode, its okay if it is turned on, but reels need to turn freely. In play mode, rollers are engaged to hold the tape against the heads. In this mode, these rollers are in the way of putting a tape in place.
    I hope I helped some............
  • gwh
    gwh Posts: 1,451
    Thanks Dennis I got it now, it's an akai GX 220D, seems to work but the output is very low, probably needs a tune up.
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • hearingimpared
    hearingimpared Posts: 21,136
    There is usually a picture or drawing somewhere on the unit displaying the threading procedures.
  • danger boy
    danger boy Posts: 15,722
    gwh wrote:
    How in the hell do you thread one of these things? (reel to reel)
    Thanks,
    G
    ;) that's old school for sure. I doubt i'd be able to remember myself. I never owned r2r, but i could prob figure it out after a while too.
    did you connect it to a tape mon input?
    PolkFest 2012, who's going>?
  • gwh
    gwh Posts: 1,451
    Yeah I plugged it in to a Fisher 500C and a boom box....Same result on both units.
    G
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • Dennis Gardner
    The azimuth (alignment) of the tape to heads is most likely off some. This affects volume.
