FS: 60'' Sony LCD RPTV $950
millerman 3732
I don't think it will do much good to list this here since no one here on the forum lives very close to me but I thought I try it anyway. Pick up is prefered but if someone want to try and ship it I'll help any way I can but its on you to setup. It is 3yrs old and I've just had the lamp replaced, it has maybe 3hrs on it so you would be set there for a couple of years. The only problem I ever had from it is that the cooling fan tends to suck up dust, I've been told this is a problem on alot of these types of sets, There are some very light surface scrathes on the top where I had my center channel mounted, There is also a small chip in the base where the idiots that I use to service it dropped it on the edge of the truck they picked it up in but its not visable from normal veiwing postions. There are pics in my system showcase you can check out if interested.
Inputs:
3 composite / S video
2 HD components
1 DVI
1 composite audio out
64''w x 42''h x 19''d, base is 40'', weighs about 100lbs
Inputs:
2 HD components
1 DVI
Casey
H/T: Epson 6500ub
Sony UBP-X800
Toshiba HD-XA2 (HD-DVD, CD)
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi 10 (bi-amped)
Polk CSi5 (bi-amped)
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
TV Rig: Samsung 50'' 4k display
Polk Signa-1 Surround bar
H/T: Epson 6500ub
Sony UBP-X800
Onkyo 805 (pre-amp)
Outlaw 7125
Polk RTi6
SVS PB 12 plus/2
Velodyne SMS-1
