Proposed new A/V stand...
Grimster74
Alright fellow Polkies, as many of you know, in the last couple of weeks with recent purchases, I've room out of room in my current a/v stand that I built. Well below is a jpeg file of a AutoCAD file with the current stand I'm designing and getting ready the build. I'd like to hear what you guys think of this design. All wood used will be 3/4" white oak and all shelves will be adjustable. I also plan on designing the back of the cabinet with cable run channels so I can seperate the power cords from the a/v cables. If you guys have any suggestions I'd love to hear them.
P.S. - make sure to view the picture at full screen if not it looks like some lines are missing.
Post edited by Grimster74 on
Here is option #2. I have removed the small section in the center and just placed the XBOX 360 on top of the center speaker. Before anyone says to make the shelf 3 shelves wide, I can't. I roughly only have 4-1/2 feet to work with width wise and roughly 3'-3" in height to the bottom of the screen.Money Talks, Mine says Goodbye Rob!!!!
I like the first one..
you don`t really want anything on top of your center speak, do ya ?
Either way , it should look real nice made out of that white oakCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Numero Uno.I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Yep. One.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Agreed #1. Can't wait to see the finished product!!!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Ditto on #1
I see you have a SMS-1, how do you like it & has it lived up to it's great reviews. I've been thinking about one myself."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
pearsall001 wrote:Ditto on #1
I absolutely love it. Everything thats been said about it in the reviews is very true. I ordered mine from OlkiePolkie here on the forum. Give him a shout, he may be able to cut you a deal on one.Money Talks, Mine says Goodbye Rob!!!! -
I like #1 but your x360 is going to be starved for air. Make sure there is plenty of room for airflow, the 360s get super hot
And put a Wii above it!
Well, picked up the lumber yesterday for my new stand, by the way, going with option #1, thanks for you inputs. Anyways, got all the lumber ripped down and cut yesterday afternoon, so now it's time to start all the pain in the **** things, like ripping the dattos for the bottom shelf, and drilling the holes in the side peices for the adjustable shelves. I will take pics of the whole build process when I get the chance so everyone can follow the build with me.Money Talks, Mine says Goodbye Rob!!!!
I've been thinking about the whole adjustable shelf thing and would like your opinions again. Instead of drilling what seems like hundreds of holes in the side peices for the adjustable shelves I came up with another idea and I'd like to hear what you guys/gals think. I was thinking instead of drilling the holes I would just datto a vertical datto on all the side peices and flush mount some brass Pilaster Strips. I think it would be alot faster than drilling the holes and then I could use the brass Pilaster clips for a more secure fit. Here is a link to what I'm talking about.
http://www.lowes.com/lowes/lkn?action=productDetail&productId=107805-46882-25209BSLLG&lpage=noneMoney Talks, Mine says Goodbye Rob!!!! -
This is what it would roughly look like.Money Talks, Mine says Goodbye Rob!!!!
I know how you guys/gals like to say threads are worthless without pics so who am I to disappoint. This is what I got done yesterday. Notice the brass palister, this is what I was talking about earlier in the thread, a whole lot faster and easier than drilling holes.Money Talks, Mine says Goodbye Rob!!!!
Looking good!
One thought: Are you going to put another sheet on the bottom to make the base flush? Or maybe another foot in the middle? I can imagine it might bow otherwise. -
Dane, as far as putting another bottom on it, negative, when I build these av stands I always put six (6) casters on the bottom, 1 in each corner and 2 down the center which prevents it from bowing. Anonymouse, apparently these Pilaster are designed to be used on bookcases so I'm hoping they will be pretty sturdy. The heaviest peice of gear I own is the 7700 amplifier which will be on the bottom shelf so that shouldn't be a problem. The next in line as far as weight goes is the pre/pro which is close to 30 lbs. and I'm more than certain it will hold the weight of the pre/pro.Money Talks, Mine says Goodbye Rob!!!!
I don't feel it will be an issue at all, my thinking is if weight was distributed evenly that may hold up to 100lbs. The clip and force will on close to side rail this helps the clip in holding this much weight.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Okay, finished the front and sides for the day. Also got all the shelves cut. Possibly tomorrow I'm going to start routing the edges and begin sanding. Here is a pic of what I got done today.Money Talks, Mine says Goodbye Rob!!!!
Here is a couple more pics.Money Talks, Mine says Goodbye Rob!!!!
Lookin' good! When you say you're planning something, you really mean it! I saw your first post of the concept drawing and a few days later you are well into the build. Good Job, indeed!!
As far as the shelf mounts, I would not worry a bit about the weight capacity. As long as the shelf is sized as large as possible without binding, those things hold massive amounts. Especially if you get the more angular (think like a roof truss style) clips (not the level ones like in your Lowe's link.) I'd be worried about cracking a shelf in half before those clips failed. I have sat on a thick shelf supported by those standards and the brass/metal clips that go with them. Now, I'm not what you'd call large, but none of your components weigh as much!
Good Job and keep it goin'! -
Grim,
That's great you can make your own cabinets any size shape style or color you want. I bet there are a lot of guy's who could use a custom made cabinet and best of all it's better than store bought.Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's -
Yeah, keeps me out of trouble with the wife when I'm out in the shed building furniture. This is like the 5th a/v stand I've built in the last year. Every time I build one someone comes along and wants to purchase it and then I end up building another one.Money Talks, Mine says Goodbye Rob!!!!
Mister, if I lived anywhere near you, I WOULD BE ONE OF THOSE PEOPLE!!!!
You do outstanding work!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Thanks cfrizz, if you were closer I would be more than happy to build you one, two even three. : )Money Talks, Mine says Goodbye Rob!!!!
What's your address I'll be knocking
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Wow that looks great! I'll definitely be giving you a shout if i ever need something like that. How much is the cost going to come to if you dont mind?Terps Swimming!
HT Setup
TV: Vizio VX32L
Reciever: Pioneer VSX-D914
HD-DVD Player: Toshiba HD-A2
Fronts: Polk R50s
Surounds: Polk R30s
Center: Polk R20's
Subwoofer: SVS 20-39PCi
2CH Setup
Integrated: Onix SP3 Tube
CD Player: Sony CDP-CX355
Speakers: Onix Strata Mini in PR Finish
Signal Cable: Classic Speaker, Analog 1 IC
Headphones
Grado SR 60, Bang & Olufsen A8, Shure e3
Other Stuff in Use
Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060 -
That is one pretty A/V stand.I can't wait to see the finished product. This is one thing I have always wanted to do, but lacked the woodworking skill to actually complete. I can design on AutoCad all day long, but building something like this is out of my reach.
Here are some recent pics taken today on the status of my new a/v cabinet.Money Talks, Mine says Goodbye Rob!!!!
Second picture is what I like to call my "wookshop of wooden wind chimes". The third picture is how I notched the back so all the audio and video cables will be seperate from the power cables. The forth picture is of the back I built, notice I will still be able to access the back of the components. Final sanding and final coat of clear is being sprayed on tomorrow and it will then come in the house on Sunday but it will sit idle till Tuesday to give it a couple of days to cure inside.Money Talks, Mine says Goodbye Rob!!!!
Absolutely outstanding!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
