Lutron IR dimmer making noise.
del44
Hey guys, I just installed a Lutron Maestro IR dimmer. Works great, but my wife noticed a high pitch sound when first turning the lights on. Was wondering if this is normal because of the IR setup in the dimmer. I can barely hear it myself. You really have to listen to hear it. And it only makes the sound when the lights are going on. Thanks
Post edited by del44 on
When i built my first HomeTheater, i had installed a Lutron IR dimmer. I programmed it to my Onkyo remote and it worked great.del44 wrote:Hey guys, I just installed a Lutron Maestro IR dimmer. Works great, but my wife noticed a high pitch sound when first turning the lights on. Was wondering if this is normal because of the IR setup in the dimmer. I can barely hear it myself. You really have to listen to hear it. And it only makes the sound when the lights are going on. Thanks
And yes, i do remember the same exact sound you are discribing. Though it was not very noticable. -
Thanks. I wanted to make sure that it might be just a normal thing.
