sda crs
hotwheelman
hotwheelman Posts: 1,300
edited February 28 in Clubhouse Archives
Why do some have one tweeter? The first pair that I listened to had two, what is the difference between the two? Just curious to know.........:confused:
"Its worked so far but we're not out yet."
"Hey big man let me hold a dollar"
Post edited by RyanC_Masimo on
    F1nut Posts: 50,657
    edited August 2002
    The early SDA's had two tweeters, one was regular and the other for the SDA effect. Polk then discovered that the SDA effect was useless in that frequency range, that it only worked in the midrange, so that's why there is only one tweeter in the later models. The bigger SDA SRS's had/have multiple tweeters, but had/have nothing to do with the SDA effect.
  • hotwheelman
    edited August 2002
    thanks for the info f1........:)
