120Wx5 amp + sub, or 200Wx5 amp?
dane_peterson
dane_peterson Posts: 1,903
edited February 2007 in Electronics
Okay guys,
My funds have depleted. I have LSi9s as mains, an LSiC as a center, and that's pretty much it. With $1400 left, here's the equipment I still need:
Surrounds
Amplifier
Subwoofer
I've decided the surrounds can hold off until after I get a sub. So the question is:
Do I buy a 120W x 5 amp? (IE Rotel RMB1075 ~ $750) and a decent sub?
Or do I invest in a nice 200W x 5 amp? (IE B-stock Outlaw 7500, or B&K 7250)
One thing to take into consideration is that I won't have another decent amount of spending money until April, so what I get now has to hold me over for several months. I've heard mixed reviews on whether or not 120w @ 8ohms is enough to bring out LSis, hence my indecisiveness.
So what would you do?
Post edited by dane_peterson on
  • Shizelbs
    Shizelbs Posts: 7,433
    You're going to want a sub no matter what.
  • louthewiz
    louthewiz Posts: 581
    Here is a good low cost amp:
    http://www.emotiva.com/lpa1.html
    My gear,
    Acer PH530 720P PJ
    100 inch Da-Lite Video Spectra screen
    Yamaha HTR 5790
    Toshiba HD-A3
    Denon 1600 dvd player with sdi out,
    DVDO iSCAN HD+
    Panasonic Dmr E-80H
    Dishnetwork HD pvr
    1 Audiosource amp300 150 wpc Fronts
    1 Audiosource ampone bridged 200 watts powering center
    1 Onkyo M-282 105 wpc amplifier sides
    polk cs400 center
    polk RT400 mains
    Polk mkII back surrounds,
    Polk FX300fxi dipole surrounds
    Velodyne DPS-10 sub
    Klipsch KSW-10 sub.:cool:
  • dane_peterson
    Let me add that I cannot have a cylinder sub, as the WAF factor is not there, and neither is the space.
    Yeah, I'm leaning toward the 12xW/channel option as home theater without a sub is pretty lame. But thought I'd see what others have to say...
    treitz3 Posts: 20,008
    If you want to purchase your system twice (or more), get the 120x5 and sub.
    You need to ask yourself....will I be happy with the 120w x5 and the sub for the long haul? Or, do I want to bite the bullet and get the 200w x5...splurging for now....experiencing and learning from that for a while...and then when the time comes.....THEN get the sub of choice?
    The latter will yeild a better end result, possibly only requiring one purchase. The only other thing you need to ask yourself...is can you be patient enough to wait?
    My question to you would be.... have you ever heard the phrase "good things come to those who wait?"
  • dane_peterson
    I understand your philosophy, and trust me, the same question has gone through my head...
    To be entirely honest, however, I don't know that 120w x 5 will be inadequate for what I'm trying to accomplish. I know that 120 @ 8ohms has been deemed inadequate for LSi15s, but I have not received that general concensus yet on the LSi9s.
    As for the sub, with my given space, I think I can find something that will suit me just fine for around $700. So it really comes back to whether the amp will do my speakers justice. I can go with the 200watts and never look back, but I'll never know if 120watts was enough to make me happy.
  • Willow
    Willow Posts: 11,233
    how about 3ch@200w and a sub. then you could add a 2 ch later or monoblocks ?
    As mentioned you will want the sub. So start buy buying the sub then with the balance buy what you can get for either a 3 or 5ch @ 200W
    FWIW I went with 3 monoblocks @ 200wpc so I wouldn't have to do buy amps twice. Later I'll buy a smal 2ch for the rears or two more monos and maybe at 120 or 150wpc since it'll be for the rears.
  • Shizelbs
    Damn thats cheap. I might get one and biamp my mains.
  • dane_peterson
    A thought I had along those lines was getting 3 Outlaw 2200s, and powering the surrounds by the receiver. But I truly don't know how capable my 2807 is of even running two LSiFXs... I'm not really fond of having two different types of amplifiers (excluding the receiver) taking up space on my already limited shelfspace.
  • phipiper10
    phipiper10 Posts: 961
    You only need a little bit of patience as April is barely a month away. Hold on to all your money, add it up with what you get in April and see how you feel then. When you have all the money together it could change your approach to your purchases.
    my .02
    Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels
  • millerman 3732
    millerman 3732 Posts: 1,488
    I'm sure you have considered this but keep in mind that the LSi are 4ohm so if you take an amp like mine (125w x 7 at 8ohm) at four ohms you will be pulling 190w x 7 almost the 200 you are looking for.
    Casey
    H/T: Epson 6500ub
    Sony UBP-X800
    Toshiba HD-XA2 (HD-DVD, CD)
    Onkyo 805 (pre-amp)
    Outlaw 7125
    Polk RTi 10 (bi-amped)
    Polk CSi5 (bi-amped)
    Polk RTi6
    SVS PB 12 plus/2
    Velodyne SMS-1
    TV Rig: Samsung 50'' 4k display
    Polk Signa-1 Surround bar
  • Ron Temple
    Ron Temple Posts: 3,212
    That Emotiva looks like a pretty nice solution...225wpc @ 4 ohms. What's the Rotel rated into 4 ohms? I doubt if you'll need to output more than 100w to get extremely loud. The rest is headroom, about 3db. It would be nice to have 6, but probably not necessary.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • dane_peterson
    Indeed, Millerman.
    I'm simply referring to all the amps in 8ohm assumption. Most amps in 200w @ 8ohms will drive around 350w @ 4ohms, which seems like a pretty solid number. But others would probably have better opinions than I... how many watts in 4ohms do I want/need to drive my LSis?
    Phipiper, I'll be getting another ~$700 in April, so it's not an enormous chunk of change. However, it is enough to buy a pair of surrounds (if I can find some used) So my hope is to have things near completion at that point.
  • dane_peterson
    The Rotel is rated at 200w @ 4ohms. Maybe it's enough? I've always really liked Rotels styling and performance. The price is right, too.
  • Poee7R
    Poee7R Posts: 906
    I would look at Adcom as a reasonable solution to what ya need.
    Look for something along the lines of a 5503, which i believe is 200@8 325@4 x 3. And grab a 545/5400 for the surrounds. With that your looking at possibly 700 give or take plus shipping. Which would leave you with 6-700 on a sub. With 600 or so you can get hip deep in an HSU or a decent SVS.
    You say youll receive another 700 or so in april, theres your surrounds.
    I would venture to say with your front 3 channels equally powered, you probably wont notice your surrounds are being fed less.
    And this is all my opinion of course, as im a bit partial to Adcom. I kinda likem... ;)
    Dave
    Once again we meet at last.
  • Shizelbs
    If April is the point at which you've have more money to burn, just wait until April. If you NEED something now, buy something used off audiogon or something that will hold you over, then sell it and make your money back. Otherwise, just wait it out.
  • cfrizz
    cfrizz Posts: 13,415
    Dane you are planning on an all LSI system. Will the 120 run all of the speakers? Yes, but it will be a heavy load for it.
    As you said... "Maybe it's enough?" Ron said... "The rest is headroom, about 3db. It would be nice to have 6, but probably not necessary."
    With as much money as you are putting out for all this equipment, I WOULDN'T WANT THERE TO BE ANY MAYBE'S OR PROBABLY'S ABOUT IT!
    The 200wpc will GET IT DONE! with room to spare. I would much rather have all that power & not need it, than to find out I did need it after I've blown out a tweeter!
    Also keep in mind that whatever other upgrades you do, your amp won't be one of them!
    Do it right the first time Dane. That way you won't have to 2nd guess, wonder, or worry about it.
    As a matter a fact I think I remember some guy came on here pooh poohing the need for so much power with the 9's. Right up until he blew out a tweeter! I'll try to find the thread & link it.
  • dane_peterson
    Yes, I believe I recall that thread myself. :)
    My Dad is coming over this evening to experience the almighty LSi9s. I'm afraid he's going to be a bit disappointed running off the 2807. :rolleyes:
  • cfrizz
    Well then you will just have to have him back over once you have them properly amplified with 200wpc!:D
  • AndyGwis
    AndyGwis Posts: 3,655
    If you get a used 5-channel amp now with $600-$700 and a sub with the rest, you should be able to resell the amp for the same price you bought it down the road, should you choose to upgrade once you've got more green in your pocket.
    I don't shy away from pulling the trigger on a great deal, even if it's only a temporary thing. I like to try stuff out, resell when I find something better, and not loose any money.
    But, to each his/her own. I can see other's point of view to just buy the biggest/baddest thing you can afford, then not worry about it for a long time.
    On an aside. . . If we played a drinking game where everyone took a shot anytime someone said "at least 200wpc" we would be getting our stomachs pumped daily.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • Shizelbs
    Yeah, this would be a great time to get something off the used market.
  • AndyGwis
    This B&K amp you were mentioning off 'gon does seem like a really good deal, especially if you can sell the IC's for a franklin or so.
    http://cls.audiogon.com/cgi-bin/cls.pl?ampsmult&1176523779
  • Ron Temple
    I do agree with Cathy...more will be better.
    My only experience (though I'm old) relates to driving my SDAs to around 100dbs, average, with 5 db peaks. The meters were measuring around 30 - 50 watts, the peaks kicked up to around 100 watts. Now I don't know if the meters were compensating to 6 ohms, it doesn't really matter to my thinking. I still had 5-6 dbs of headroom and there is no way I was going to crank it any louder.
    Since the SDAs can handle 500wpc @ 6 ohms, I was considering a bigger amp, but have now realized that in this room, I can't or won't ever need more headroom for these speakers. My amp can provide ~ 300-325wpc RMS @ 6ohms. Not to say that an amp that can give them 5-600 watts won't sound better, IDK. I just won't make that decision based on what my room will require from the amp.
    Futureproof your purchasing decision as best you can...but, hell you'll probably want to upgrade in a year, just because...;)
    Combo rig:
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • MSALLA
    MSALLA Posts: 1,602
    I think this is your best bet. 120 watts of high current power is enough to drive your speakers, but you don't seem comfortable with it and will probably always wonder if 200 would be better so go for the 200 now. You MUST run a sub though. You don't have surrounds yet so I wouldn't worry about powering them at this point. I'm in the same boat you are as far as money. Just have to be patient.
    Michael
    Samsung 50" HD DLP
    Yamaha RX-V2500
    (2) Outlaw 200
    Adcom GFA 555
    Sony BDP300
    Denon 2900 DVD
    Lsi9's mains
    Lsi7's rear
    Lsic center
    12.1 SVS driver in 4.53 cuft. tube
    Harmony 880
  • cfrizz
    Here it is. It turned out to be a hilarious thread!
    http://www.polkaudio.com/forums/showthread.php?t=45029
  • Willow
    cfrizz wrote:
    With as much money as you are putting out for all this equipment, I WOULDN'T WANT THERE TO BE ANY MAYBE'S OR PROBABLY'S ABOUT IT! Do it right the first time Dane. That way you won't have to 2nd guess, wonder, or worry about it..
    I have to agree with CFrizz , after all it was this same info which lead me to buy her outlaw mono and buy two other (Marant monos) but all @ 200ws.
    It'll cover my butt, for my next set of speakers , casue I'm sure there will be more...many more. Just can't let my wife see me type this, or she'll have my current speakers on the FM with my in a coffin ;)
