Dual Mono vs. Stereo
ledhed
ledhed Posts: 1,088
edited February 2007 in Electronics
Ok, so a few amp kits I'm looking at (such as the LM60 from ampslab) are single mono channels that I would then use in one chassis as a dual mono design.
My question is just what is the difference between dual mono as opposed to stereo? Shouldn't the source/pre-amp do all the stereo work and in the amp it doesn't matter? Or would I not have a true stereo rig? What would be the pro/cons?
God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
Post edited by ledhed on
  • Systems
    Systems Posts: 14,873
    Dual mono simply means that two completey separate amp channels,each with their own power supply are assembled into one chassis.A stereo unit has two channels but they share a common power supply in one chassis.
    Testing
    Testing
    Testing
  • ledhed
    ledhed Posts: 1,088
    So, this changes nothing in the way they theoretically sound or a signal is processed correct?
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    There should be no cross talk between channel's with the mono blocks and a dedicated power supply for each amp.
    I'm a newb to this but that is what I believe is the benefit.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • Systems
    Correct. They are both stereo.
    Testing
    Testing
    Testing
  • ledhed
    ledhed Posts: 1,088
    Great, thats what I thought
    F1nut Posts: 51,768
    No, amps matter. Each has an unique sound that comes out in the mix as do the characteristics of dual mono, mono blocks and stereo configurations. To say they are all stereo is oversimplifying the matter.
  • ledhed
    ledhed Posts: 1,088
    Well, let me be much more specific; will I lose anything in the way of stereographic projection, if the recording itself was recorded that way?
    F1nut Posts: 51,768
    Hmmm.....let me say it another way. They all produce stereo sound, but they have their own characteristics or sonic signature based on design and configuration.
  • ledhed
    ledhed Posts: 1,088
    Right, well I knew that. Otherwise I'd just be content with a low cost AVR ;)
    F1nut Posts: 51,768
    Oki doki then...maybe I'm not getting what you are after.
  • ledhed
    ledhed Posts: 1,088
    No, you answered it perfectly. I wanted to make sure the sound coming out would still technically be stereo. Thanks for all your help guys!
    F1nut Posts: 51,768
    In that case, you're golden.
