PSW 303 Hum
mvsainsbury
Just bought a new surround system:
Polk RM 20
Polk PSW 303 sub
Onkyo TX-SR674
I'm expierencing a hum on some of the different surround settings. I purchased the ground loop isolator, suggested in the manual, but it doesn't seem to do anything. Any other suggestions -- I'm guessing this is not that uncommon, there must be a better solution.
Polk RM 20
Polk PSW 303 sub
Onkyo TX-SR674
Post edited by mvsainsbury on
Check for loose connections or redundant connections (if you happened to wire two things into the same input). That is where I would start.
Check if "Double Bass" or something like that in your Onkyo's settings is set to "on". It bridges the front's low frequency portion + all other speakers set to small + the LFE to the sub. Sometimes the front channels fed to the sub on my Onkyo cause the sub to hum.
This setting creates a redundant connection, i.e. it is like connecting both speaker-level and line-level inputs to the sub.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
