amperage
livewire
livewire Posts: 26
edited February 2007 in Electronics
I know i've asked a similar question but does amperage(PEEK TO PEEK) per channel really matter????????
Post edited by livewire on
  • Systems
    Systems Posts: 14,873
    An amp with greater current capability will be better able to drive low impedance loads of say 4 ohms or less.
    Testing
    Testing
    Testing
  • dudeinaroom
    dudeinaroom Posts: 3,609
    if your not running 4 ohms or lower speakers, I really would not worry about it, if your using it for bookshelve speaker I would not worry about it, you would do a little better with higer voltage on a smaller speaker, where as big low impedance woofers or multi driver (more than 3, or more than 2 of the same size) you would do better with a higher amperage amp, as it will have the extra current to control the drivers.
  • livewire
    livewire Posts: 26
  • sickicw
    sickicw Posts: 456
    While average current is usually pretty low, peek to peek amperage in an ideal situation can be quite large. This is especially true in movie soundtracks with large dynamic ranges. As a general rule, the lower the impedance of the speaker, the more current you will need. However, even 8 ohm speakers could greatly benefit from a high current amp.
    EDIT: As a side note, even a high current amp may be starved for current if it is not given the proper power input. Most high current amps will need a dedicated power line to perform best. If a dedicated power line is not available, a large (1 – 5kW) balanced power transformer will be helpful. Of course the transformer would be much, much more expensive the dedicated power line.
    Speakers: LSi9 x 2, LSic, LSiFX x 2, Velodyne HGS-15
    Amps & Power: Rockford Fosgate T8004 x 3, Cascade Audio APS-55 power supplies x 5, and 1 farad capacitor.
    Electronics: Denon 3806, Toshiba HD-A1, & Sony KDL46XBR2
    Accessories: Anti-IC interconnects, 8 Mondo Traps from Realtraps, and Salamander furniture.
