SVS 20-39 CS-Plus
TB Cruzer
TB Cruzer Posts: 27
I was looking at buying a 20-39 CS-Plus. I have a HK AVR-7300 receiver. I can't seem to find whether or not it controls subwoofer phase. If it doesn't, how bad of a thing is it?
Samsung 52" Flat Panel LCD
Sunfire TGP-5
Sunfire TGA-7400
Sony S300 Blue-ray
RTi12, CSi5, FXi5
SVS 20-39 CS Plus
Post edited by TB Cruzer on
  • McLoki
    McLoki Posts: 5,231
    edited February 2007
    What are you going to run the SVS with? (what kind of amp?)
    Your reciever will only provide a low level signal meant for an amplifier of some kind to amplify and they send on to your sub. You can get any kind of amp you want to do that. If you purchase a subwoofer amp. (like a plate amp from parts express) it will have a phase control on it. Without that - you can only control phase as in-phase or 180degrees. (reverse the speaker cables)
    I use a standard amp and have no issues at all with phase. From the testing I have done with other subs in my environment - I have never really been able to hear the difference that changing the phase made. I would not worry overmuch about it.
    Michael
  • Serendipity
    Serendipity Posts: 6,975
    The sub does not have any way to control phase other than by switching the wires on your amp.
    Unless you buy a "dedicated" subwoofer amp with phase controls...
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Lowell_M
    Lowell_M Posts: 1,660
    By the way...I think you should let your HK power the rears and bridge one of those Carver monsters for the SVS.
    You're going to scare the dog. Who knows what will happen to the cat.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
    Signal Cable Analog II IC's
    Signal Ultra Bi-Wire Speaker Cables
  • Lowell_M
    I've 'heard TB's setup and it sounds great. These are the first RTi12's I've listened to. I was surprised at how deep they dig. So, what are some recommended crossover points for these? He's got a boatload of power going to the 12's, and will have a nice amp powering the SVS.
    HT
    RTi70 mains
    CSi30 center
    RTi28 Rears
    Velodyne CHT-12
    H/K AVR-247
    ADCOM GFA-7000
    Samsung PN58B860
    Playstation 3
    2-Channel
    Polk Audio LSi15's
    Rotel RCD-1072
    Nakamichi CA-5 Pre
    ADCOM GFA-555
  • TB Cruzer
    TB Cruzer Posts: 27
    I'll use the spare channel on one of my Carver M1.0ts to drive the sub. The other is driving the center channel. That amp is rated at 500 watts at 4 ohm, so it should get plenty of power.
    By the way, I already ordered it.
    The dog will be fine, and hopefully the cat dies of a heart attach!!!!
    Sunfire TGP-5
    Sunfire TGA-7400
    Sony S300 Blue-ray
    RTi12, CSi5, FXi5
    SVS 20-39 CS Plus
