Tube Bias
MillerLiteScott
MillerLiteScott Posts: 2,561
edited February 2007 in 2 Channel Audio
I do not know what to set my multi-meter on to read the tube bias?
Also which inputs do I put the probes in the multi-meter?
Picture below.
The biasing instructions say 330mV +/- 5%.
MLS
I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
Post edited by MillerLiteScott on
  • Ricardo
    Ricardo Posts: 10,636
    Black probe in Common.
    Red probe in V
    You should select the DC Volts; I think it's the black one (looking at the scales), but I'm really not sure; the manual of the multimeter should tell you.
    You need to measure 330mV, so select the "2".
    Edit: when you're ready to roll some tubes, try the JAN-Philips 6L6WGB..they are expensive, but the difference is worth it. If the AV-25 is like the AV-20 (which I think it is), you can also use EL34's, and I think KT66 can also be used. Lots of possibilities.
    Edit 2: not sure how many decimals that multimeter will display when you select 2 in the scale; if it displays only one decimal, you'll be limited to 0.3 vs. 0.33; if this is the case, maybe for $20 or so you can look for one that can measure more mV's (vs. 200mV max on that one).
    And yet one more edit...I see you have the monoblocks with the M5's as the "budget 2 channel"; maybe it is, but music will sound so much better than in your RTi rig; you'll love it :)
    SOPA
  • MillerLiteScott
    Thanks HTrookie.
    That was it and I have both tubes in the one amp at 334 and 336.
    The manual says to wait 10 minutes and check it again.
    At the "2" position it was .334 Is that right?
    MLS
    mhardy6647 Posts: 33,960
    .334 VDC is 334 mV. Sounds fine to me.
  • MillerLiteScott
    There is a sheet of paper that is for the Wave AV-20 that says 330mV and in the manual for the Wave AV-25DT which is what I have says 350mV.
    I ave both tubes in both amps set at @ 341-342mV after being on for 10 minutes. If I remember correctly Mark said that if I set them anywhere @ 330mV-350mV I should be fine.
    I am going to give them a try in about an hour after the kids finish watching
    A Bugs Life.
    after the kids finish watching A Bugs Life.
    A perfect time interval to let an amp warm up before checking the bias :-)
  • dorokusai
    dorokusai Posts: 25,577
    You're ok Scott, that's perfect. As aforementioned, check them again after the movie but you should be fine after that. It's always good to recheck them every now and then.
    After the first few rounds you'll have a better perspective on what interval to check bias in the future.
  • MillerLiteScott
    What does the bias(ing) affect?
  • audiobliss
    audiobliss Posts: 12,518
    The voltage going to the tubes, no? I'm not sure, either...
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • RuSsMaN
    RuSsMaN Posts: 17,986
    In a nutshell, it is the negative voltage applied to a tube's control grid which allows the tube to stay within its operational parameters for your specific amplifier. Too much bias, the amp will sound like poo. Too little, tubes can overheat and fail, taking output transformers and other parts in the circuit with them.
    Cheers,
    Russ
    We ask a tube to amplify an AC waveform, which (typically) varies both above and below zero volts. The problem is, electrons are always only negatively charged. The bias shifts the zero point of the waveform so that the tube can linearly amplify both the "+" and the "-" component of the waveform.
    http://www.pcmag.com/encyclopedia_term/0,2542,t=bias&i=38587,00.asp
  • MillerLiteScott
    Thanks.
    To much bias and sound like poo poo.
    To little is bad.
    MLS
  • dorokusai
    If you haven't seen a tube flare up, glow fire engine red/orange and then POP!....you haven't lived.
  • pblanc
    pblanc Posts: 261
    Sounds like cooking hot dogs over the campfire in Boy Scouts. How do those popped tubes taste?
  • dorokusai
    Crunchy & painful with a hint of terragon.
