Subwoofer fuse keeps blowing
freedomzxcv
I tried to replace the 2amp/ 250 volt fuse in my subwoofer today. I blew 4 fuses, each the second it was plugged into the wall socket. Any ideas?
Post edited by freedomzxcv on
sub type, sub make, etc would help
My guess something in the amp is malfuntioning and welcome aboard guyShoot the jumper.....................BALLIN.............!!!!!
amp is bad or short on sub speaker wires check it out dont plug it in till you check hew amp and conectons
goingganzo wrote:amp is bad or short on sub speaker wires check it out dont plug it in till you check hew amp and conectons
Dingdingding! You get a cookie
Brian Knauss
ex-Electrical Engineer for Polk
