which are the better speakers?
I going out tomorrow to buy some new speakers and I would like to know the difference and which are better speakers - between the m20's, r30's and r300's. If someone could help I would appreciate it.
Post edited by JEREMYK on
After you listen to each of them, with music you are familar with, let us know.
Cheers,
I am mainly using them for HT. I am replacing a set of monster Cerwin Vega towers that my wife says takes up to much room. I do not expect any of these to be able to replace the power of my old towers. They each had a 15" woofer, 6 midrange drivers and a super tweeter. I listen to all types of music - just not as loud as I use to. I have a Yamaha 125watt per channel 6.1 receiver and center and surrounds are polk. i will also be adding a polk sub.
Best to let the powers that be know which Polk speakers you have to better let you know suggestions. What have ya got?
See post #2DKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
I guess I'm confused at why you're replacing your Cerwin Vega's? What is it about them that you don't like? The Polk's you're looking at are the lowest in the line speakers that Polk offers.JEREMYK wrote:I am mainly using them for HT. I am replacing a set of monster Cerwin Vega towers that my wife says takes up to much room. I do not expect any of these to be able to replace the power of my old towers. They each had a 15" woofer, 6 midrange drivers and a super tweeter. I listen to all types of music - just not as loud as I use to. I have a Yamaha 125watt per channel 6.1 receiver and center and surrounds are polk. i will also be adding a polk sub.
As for a comparison between the M20, the R30, and the R300, there should be practically no sonic differences: from my understanding, they're only differently cosmetically.Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II -
he`s replacing them because the wife say`s they take up too much room...
He also doesn`t need such a large speak , as he doesn`t listen a high volumes much anymore..
Like he stated in post #2
I don`t get what`s so confusing to ya refer dude..!!
:rolleyes:Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
JEREMYK wrote:I going out tomorrow to buy some new speakers and I would like to know the difference and which are better speakers - between the m20's, r30's and r300's. If someone could help I would appreciate it.
What's your budget? maybe you can step up to the RTi line and bypass the R line.PolkFest 2012, who's going>?
I had a set of R-30's, R-15's and a M series center and they are no where near the same tonally. I also tried out a set of rti's, so here is my take.
The R's are more neutral than any of them.They do not accentuate the highs of lows, kinda flat of a response.
The M's go very bright, accentuating the highs, against the R's and RTi's. Uses a larger different tweeter, but its mid also player brighter.
The RTi's use a very, very good tweeter against either other model, but its mid is similar in tonal characteristics and the R series.
New R lineup with the flipped mid and tweeter?????
