Parasound PHP850 Owners!
audiobliss
audiobliss Posts: 12,518
edited February 2007 in Electronics
Is there a switch somewhere inside the Parasound P/HP-850 that you have to change to select MC/MM for the phono stage? I just received my turntable (yahoo! Thanks ESAVINON!!!!), and I hooked it up and it works. But I was wondering if there's a switch I should set, and if so, what I should set it to.
Thanks!
Jstas wrote: »
In Use
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Post edited by audiobliss on
  • audiobliss
    Ok, I think I answered that question. I googled it and found out I don't have a switch from this:
    The only shortcoming [of the P/HP-850] is in the phono input; at a single sensitivity of 2.5mV, it will handle a MM cartridge okay, a high-output MC so-so but not a low-output MC.
    So, now...what type of cartridge does the Denon DP-7F have?
    I think I'll return to google, though can't cartridges be changed, and so the type wouldnt' necessarily be constant with a TT?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • ohskigod
    ohskigod Posts: 6,505
    I allways get them mixed up (the whole mm/mc thing), but MM's seem to be more prevalent.
    basically, if it sounds ok, then your good. having the wrong cartridge type would be very noticable (extremly thin and tinny)
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • audiobliss
    Ok, cool. Thanks for the info!
    Didn't know the asking price (of the preamp) included free technical support! :D
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • shack
    shack Posts: 11,154
    This thread gives you some info on the MM/MC cartridge issue.
    http://www.polkaudio.com/forums/showthread.php?p=552182
    Chances are the Denon has a MM cart.
  • audiobliss
    Thanks for the link, Shack. I'll check it out..after I finish rocking out to my YES! record. :D
    It has an Audio Technica AT90 cart. I googled it, didn't find out much about it, and couldn't resist spinning some vinyl any longer!
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • ohskigod
    AT cart? yeah, thats a MM your good to go
    and yes, I'm allways a full service guy when it comes to the stuff I sell. glad that thing is still serving you well. great pre
  • bikerboy
    bikerboy Posts: 1,235
    Hi AB,
    That cart is a mm. If it was a mc the volume would be very low even at max volume on the preamp. So turn the yes up to 11 and rock. :)
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • audiobliss
    bikerboy wrote:
    Hi AB,
    Hehe, that's a good album to rock out to! :D I'm really digging that album, too, which surprises me since I really don't like the only CD of theirs I have.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
