Crossover help
Creamedweasel
Creamedweasel Posts: 1
edited February 2007 in Car Audio & Electronics
Heh call me old fashioned retarded, but I just purchased the MM6 component set and was wondering how to open the crossover case? It's the silver case with dual yellow design grills on top. Any help would be greatly appreciated. Thanks!
Post edited by Creamedweasel on
  • DemonAstroth
    DemonAstroth Posts: 131
    I had just bought one too... and I found it just as difficult. The reason was that I was trying to be too gentle.
    Hold it from the sides (the top silver part), and then from just one end (doesn't matter which) pull the bottom (black) part off, slightly pulling outwards. There are some plastic tabs. Once you get one side the other will be also done.
    Demon
  • 1996blackmax
    1996blackmax Posts: 2,436
    I remember trying to pull apart the x-over covers from my DB3065's. At first they felt like they were going to brake, but evenutally popped off.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • MacLeod
    MacLeod Posts: 14,358
    You can take a knife and push in the tabs to pull them out.
  • exalted512
    exalted512 Posts: 10,734
    I found a butter knife works best, those things are a huge PITA. That, or upgrade to the SR's, its a breeze to get those apart:D
    -Cody
  • 1996blackmax
    Actually that is what I used..... you'd be amazed how much stuff you can do with a good butter knife.
    You can always go active :D.
    I may pick up another set of Rainbows (from their Profi line)..... if I do, that may be the way I go.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
