Antique Sound Lab AV-20 Mods.
Ricardo
Ricardo Posts: 10,636
edited February 2007 in Electronics
I mentioned I would do these mods in another thread, but decided to create a thread of its own.
I got these little monoblocks a couple of months ago, and even though I liked their sound, I wanted to do some mods to make them better. I guess a part of me really enjoys the DIY side of audio; it is very satisfying to modify something yourself and actually hear a difference, plus, you learn a lot. I was done with crossovers (no more to upgrade), so I needed a new project.
I started investigating what could be done to these amps; recently I needed the bias instructions/settings for these amps and emailed Divertech.com (ASL distributors), from where Tash Goka quickly replied with the document I needed, so I decided to try them. This same guy replied and suggested the following mods:
-Swap the power transformer with the one for the ASL AV-25; this would increase power plus eliminate any hum (which they had). Basically this is the only difference between the AV-20 and the AV-25.
-Change coupling capacitors, using Mundorf Supreme Silver/Gold; this single mod would increase the level of details, he used the word "amazing" to describe what this could do.
-Change a few resistors in the signal path, which would help achieve what the Mundorf cap could bring, plus reduce noise.
So I went ahead and ordered all the parts; transformers and Mundorf caps from divertech.com, and VISHAY resistors from partsconnexion.com
The work was relatively easy; cut and solder wires, swap components in a board, etc. The one "special" thing I had to do was enlarge the holes for the caps to make the leads fit.
I am using the monoblocks to power a pair of Von Schweikert VR-1 monitors. These monitors have great detail; from their web page: ..."Not only does this new tweeter sound extremely clean, it is also unusually lush, with a smoothness simply not found in common dome tweeters. If you like ribbon or electrostatic drivers, you will love the VR-1."...and as you all know, I loved them so much that I sold my AL-III's ;)
Results:
Quiet, quiet, dead quiet. Unbelievable how a tube amp can be this...yes, quiet. The hum really didn't bother me, but it's nice to see that it's gone.
Soundstage; it's wider; it projects beyond the speakers. I really have no idea what change did this, but I'll take it.
Details: the Mundorf require 100 hours to brake in; they have about three hours now, and I already hear MORE details than before. This also helps imaging a lot. Amazing what just one little capacitor can do. No more regrets for letting the ribbons go :)
So yes; I'm a happy camper; the bad news? Project is done. It won't be long before I start looking into something else...hmmmm...Mundorf caps for the SDA crossovers???
Some pictures:
SOPA
Post edited by Ricardo on
  • george daniel
    george daniel Posts: 12,096
    nice work Ricardo,, I see that you have your diy upgrade on :) Have fun ;)
  • Ricardo
    Thanks George; yes, I really enjoy the DIY.....so far it has been only improvements, which are fine; it gets dangerous when you try to fix something that doesn't need it :)
    SOPA
  • dorokusai
    dorokusai Posts: 25,577
    Cool upgrade HT.....MillerLiteScott, you paying attention?...these are your future babies :D
  • MillerLiteScott
    MillerLiteScott Posts: 2,561
    Hey DIY rookie sounds like some cool mods. What was your out of pocket for these mods because I just bought some ASL mono blocks from Doro.
    It will be a while before make any modifications but I am a DIY kind of guy myself.
    I am paying attention. I have been all over this thread.
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
  • audiobliss
    audiobliss Posts: 12,518
    Thanks for posting that, HTrookie! I'm not sure if I'll ever get brave enough to fiddle with audio equipment that works before I take it apart, but if I do, I'd be interested in this.
    If you don't mind me asking, about what did all the parts run you?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • Ricardo
    Without the transformers it's around $100 (I think Millerlitescott got the AV-25??); Transformers were around $170 for the two of them, for Audiobliss that I think has the AV-20's??
    SOPA
  • dorokusai
    The amps are almost identical, just capacity changes.
  • audiobliss
    Yep, you got it right on both counts.
    Not cheap, but not too expensive, either.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
