Windows IE 7 problems???
hearingimpared
hearingimpared Posts: 21,136
edited May 2011 in The Clubhouse
I've been running IE 7 for about a month now and it crashes often. Is anyone having the same problems? If so can I just deinstall and reinstall it without worrying about my favorites being lost.
Effing Microsoft want $59 to answer these questions.
Post edited by hearingimpared on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited February 2007
    I haven't had it crash, but every now and then links do nothing. Ie, a link to open a new window with a picture, a link to open a video in media player, etc etc.
  • Systems
    Systems Posts: 14,873
    Hello
    If you aren't using Firefox I would recommend you go to that browser, you'll have alot less issues with it. When you install it, it will ask you if you want to move the favorites from IE to that browser. Also, if you decide to use it download the Fasterfox plugin, it will help speed up browsing. This is what I use and I only use IE for the windows updates.....
    Heres the link to download it:
    http://www.mozilla.com/en-US/
    And heres the Fasterfox add-on:
    https://addons.mozilla.org/firefox/1269/
    Testing
    Testing
    Testing
  • Disc Jockey
    Disc Jockey Posts: 1,013
    You might want to try disabling your add-ons (tools-internet options-programs-manage add-ons) one by one to see if one of them is causing a problem. Kind of a pita since there's often 40 or more of them but it fixed that problem for a couple of friends of mine.
    I don't remember if favorites are saved when you uninstall but I think they are. To be sure, you can export your favorites before you uninstall and then they'll be saved to import if need be when you reinstall.
    "The secret of happiness is freedom. The secret of freedom is courage." Thucydides
  • MacLeod
    MacLeod Posts: 14,358
    Ive been using mine for several months now and havent had a single problem. Hopefully it stays that way.
  • Fireman32
    Fireman32 Posts: 4,845
    Havent had any problems with IE7 yet but I do use firefox and think it is a better browser.
  • ben62670
    ben62670 Posts: 15,969
    IE7 sucks. It works on some machines, but in general it slows machines down, has issues with Quick Books. I would recommend staying away from it. IE6 goes anywhere that IE7 can.
    Ben
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    I use firefox because I had that problem. I just restored my system back to ie6 and downloaded firefox
  • hearingimpared
    Thanks for the feedback folks.:)
  • brettw22
    brettw22 Posts: 7,623
    Windows update just updated mine to IE7 and every time I try to start IE it crashed. I use Firefox 99.9% of the time, but sometimes i need to use IE to view a page correctly, but apparently can't do that any more. Such a POS.........
  • TN_Polk_Lover
    TN_Polk_Lover Posts: 243
    I've been using IE7 for several months and have not had any problems at all. I know some guys at work who use Firefox and they say it is faster. I really do like the tabs in IE7.
    Robert
    You are officially in the high-end of the deep-end of the top-end.
    Bonus Room Over Garage:
    Toshiba 27" CRT TV
    Digital Source: Sony DVP-NS3100ES
    DVR: Panasonic DMR-ES15
    Denon 3806 AV Receiver
    - L/R Preamp out to Parasound HCA-1200 Amp
    Polk RTi70's, CSi40 Center, RTi38 Side Surrounds, RTi38 Back Surrounds
    Living Room: (2ch only)
    TV: Sony KV20-FV12
    DVD Player: Sony DVP-NS715P
    Yamaha R9 Receiver Polk RTi38's
  • brettw22
    Well I had to disable Web History in Google Desktop to resolve the instant crashing as soon as I opened IE7. Now that I did that I can use it (still only a backup at best to Firefox)........
  • BaggedLancer
    BaggedLancer Posts: 6,371
    edited May 2011
    Don't worry i will help You,You can use the Firefox browser that is best one ....Rather Windows IE..(Internet Explorer)..Because Firefox consists many Addons,Easy to browse,manage downloads,Good for open more tabs at same time,But it will be fast even open more tabs in single Firefox browser,I am using 4th version of it speed is good ,i check my connection uploading,downloading speed while using that browser ,it's fine ...I checked at here Internet-speed-test/
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    edited May 2011
  • inspiredsports
    inspiredsports Posts: 5,501
    edited May 2011
    Post #16 by nefs902 reported as spam for removal
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • JimKellyfan
    JimKellyfan Posts: 696
    edited May 2011
    Need a little more info on your unit.
    32 or 64 bit ?
    RAM ?
    processor ?
    I have an old Sony that is still fairly quick with the 32 bit.
    I have a 2009 Acer that is really bottom of the top of the line, 64 bit and have always had issue with it, merely the sum of the parts.
    Then, I have a 32 bit Dell Latitude laptop that is fantastic as well.
    But, the Acer, learned my lesson and will have to live with its occasional lethargy.
    I am on IE9, and Winders 7 with all 3 units.
    I keep em all clean with CCleaner and Smart Defrag and of course back em up.
    Cept the laptop, no back up on it.
    Anyway, whatcha got ?
    Onkyo TX-NR636
    Main - polkaudio Monitor 60's
    Center - polkaudio CSI A6
    Sub - polkaudio PSW10
    Sub2 - polkaudio PSW505
    Surrounds - polkaudio Monitor 40 series II
    Front Height - polkaudio Monitor 40's
    Audio Outdoors
    Pioneer VSX 406 - polkaudio Atrium 5
    Shed
    Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
    Shed 2
    Nakamichi soundbar
  • Sherardp
    Sherardp Posts: 8,038
    edited May 2011
    32 or 64 bit ?
    RAM ?
    processor ?
    Good info but see the post above you
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited May 2011
    I recommend google chrome!!!
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • nadams
    nadams Posts: 5,877
    edited May 2011
    I recommend time travel to 4 years ago!
    Ludicrous gibs!
  • newrival
    newrival Posts: 2,017
    edited May 2011
    +1
    I recommend anything but ie7
    ie9 is pretty darn nice.
    chrome is simple but some pages come out funky
    firefox 4 is pretty awesome. some great plugins
  • JimKellyfan
    edited May 2011
    I use both, really. (both latest versions of IE and GC).
    For GC, you have to keep it up to date manually, but is a great browser.
    I misunderstood as having issues with machine crashing.
    It is just the browser then.
    IE9 is almost a copy cat of GC.
    I had issues with most of IE versions.
    I believe 6 was good, and 8 showed promise, but crashed or better yet hung often.
    9 I haven't had any issue other than figuring it out.
    Onkyo TX-NR636
    Audio Outdoors
    Shed
    Shed 2
    Nakamichi soundbar
