on walls
Have any of you had any experience good or bad with on walls? In my HT, I have a B&K 5 channel amp, a Ref 30 and a Denon 2900. My present speakers are either Paradigm Studio 100's and matching center & surrounds. Or I have some RT55i's with matching center and surrounds. The room is kinda small 11 x18 and the 100's eat up alot of floor space. The 55's eat up just as much when put on stands.
Since the room is used for more than HT, but not for serious music listening, I thought on walls might be a possible answer.
Any inputs? Gordon
Any inputs? Gordon
2 Channel -
Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
Post edited by Hawkeye on
You mean something like this? This is an ideal setup for HT. Place the speakers slighty behind the listening position unless you're running bi/dipoles. In which case I place them even with the listening position.
