Cable Question
No idea, but for that price, it's either a great deal or garbage_________________________________________________
Try this from the same seller for DIY speaker cables: http://cgi.ebay.com/eBayISAPI.dll?ViewItem&item=330088512899HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I would not use it for speaker cable. I would however use it for interconnects. You need to get good ends, and use silver solder.
I would recommend using the fallowing products
Ends
http://store.haveinc.com/Ebus30/Parts/Part.asp?Part=NEUNYS373BLA&Material_Code=CURRENT
Cable
http://www.sjmediasystem.com/l-4e5c-bk.html
You will end up with a cable just like the Encore II's.
I have spent a lot of time researching DIY cables, and for about 10$ and some time you can easily build cables that cost more than $80 a pair, and they are the length that you need.
Ben
