Computer Help Desk... Help please ;)
disneyjoe7
disneyjoe7 Posts: 11,435
edited February 2007 in The Clubhouse
Strange one auto update is on this update will not go away, states it's ok but then comes back. Turned off went to Windows update site stated yes I needed it redid for the 25th time, comes back.
File name MSXML 4.0 SP2 Security Update (KB927978)
Thanks Steve I'm lost. :(
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
  • Deadof_knight
    Deadof_knight Posts: 980
    once you reach sp2 turn it off for awhile. Really .......
    uninstall that one and go on......
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
  • disneyjoe7
    Confused when I reach sp2 I assume I running that now. Uninstall what?
    Can I get that in old guy computer terms? :)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Deadof_knight
    MSXML 4.0 SP2 look up all your updates and take some of them off IMHO not all of them are needed I mean really. I run nortons , partitioned real good , and I have no problems if I do I simply will reinstall windows and some related software. Its a good thing to seperate your hard drive at least 10 to 15 gb for windows xp and all the damn updates . I run a 2.4 giga hertz processor when I click I expect it to happen right now..... not in a second. I have my drive partitioned into 5 partitions. I run my Nortons ( which to some is not the best) but I have no quams with it. Take a look at all your updates and simply uninstall back past that previously mentioned and turn off updates for a lil while you might have something software wise msxml doesnt like at all. there are hmmm several things that interact with windows(nortons one of them) thats can cause problems. anytime you update make sure you have a restore point and if it act weird backup to the last restore point. pretty simple ( sometime you dont think that though) let me know Im sure we can get your trouble worked out.
  • Deadof_knight
    right click my computer if it says sp2 after youve clicked properties then your there you just have to simply get rid of the msxml update to probably to fix where your at.
  • disneyjoe7
    Ok understand I have SP2 so I just did something to remove so stupid message I could tell you but still a little confused and personally don't give a **** about some stupid message now since I killed it.
    If it Kills my laptop then I will care once again.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Deadof_knight
    I too am running a laptop so keep me upto date we can overcome problems such as these ...
    No problem just let me know if I can help
  • disneyjoe7
    Thanks, Deadof Knight I look into it deeper tomorrow as I'm off laptop and now on computer #3 too many computers some times.
    But what you stated I could delete some of the updates?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    Ok I got it. It's a program download so I could delete it then try to see if it loads ok. I think ;) Well I see that program on computer #3, which is running ok knock on wood.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    This starting to make me think about that Mac / PC commercial when he goes in for the Vista update.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    Ok I deleted it, re-powered the laptop computer, then I did windows update... I couldn't believe it I have 11 updates, downloaded all, rebooted the computer all ok now. ;)
    Thanks again for your help Deadof_Knight.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
