How do I rip a DVD?
madmax
Just got one of those Creative Vision: M psp players. How do I rip a DVD to put on it?
madmax
madmax
Vinyl, the final frontier...
Post edited by madmax on
I don't know what you would use to burn the disk, but you could rip it with dvd shrink, or dvd decrypter dvd shrink will also compress the file to a smaller size if need be.
I'll look for that program. No need to burn it to disc. Once I get it on my hard drive I only need to drag and drop onto the player. Divx is native to the player so if I find something that encodes in that format I'm really set. So far I've loaded several seasons of Married With Children from a Divx disc and that worked fine. I'm really liking this player! Isn't technology wonderful.
I'm sure there are freeware programs but, slysoft makes this http://www.slysoft.com/en/clonedvd-mobile.html which takes away any guess workGod shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
I use dvd decrypter first and then AutoGK from there. It takes a long time to process a dvd but it produces by far the best quality files I've seen (size to quality ratio). It'll bring down a 20 minute tv show down to 40mb at 320x240 resolution (for my pocket pc) and have it still look great. Don't really have time to write up instructions on how to rip a dvd. I'll try and find a link for a tutorial.
Another program that's a little less complicated and faster (but worse quality) is Pocket DivX Encoder. This is to bring down the size of videos (not straight from dvd).
edit: Give this a read. Linky.
If it doesn't work for you just pm me or post here and I can help you out. -
My gear,
Acer PH530 720P PJ
100 inch Da-Lite Video Spectra screen
Yamaha HTR 5790
Toshiba HD-A3
Denon 1600 dvd player with sdi out,
DVDO iSCAN HD+
Panasonic Dmr E-80H
Dishnetwork HD pvr
1 Audiosource amp300 150 wpc Fronts
1 Audiosource ampone bridged 200 watts powering center
1 Onkyo M-282 105 wpc amplifier sides
polk cs400 center
polk RT400 mains
Polk mkII back surrounds,
Polk FX300fxi dipole surrounds
Velodyne DPS-10 sub
Klipsch KSW-10 sub.:cool: -
You should also get a subscription to Rhapsody. $15 a month and a la carte music uploads to your player, as much as you want, from around 3 million songs. The only section that is lacking is Electronic, but everything else is great.Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II -
