Question
PolkFan1
PolkFan1 Posts: 130
edited February 2007 in Speakers
Is 35 watts added to your main speakers only from the receiver going to do any significant change it performance?
Post edited by PolkFan1 on
  • MikeC78
    MikeC78 Posts: 2,315
    What are you asking??
    Is 35watt/channel suffice for speakers?? What speakers, what receiver do you have? There are many variables that would make 35 watts ok.
    Mike
  • PolkFan1
    PolkFan1 Posts: 130
    I mean, my current receiver(yamaha htr-5740) puts out around 85 wpc in stereo. So if I were to get something with 120 watts per channel(HK3480) in stereo would that make a signicant difference in sound? Its a difference of around 30 or so watts...I have the rti8's
    I am planning on picking up the HK today from everyone help i had earlier...just wondering what more the HK is gonna do
  • MikeC78
    Yes, that H/K will beat the snot out of those Yammy watts by a huge margin!
    You will be a lot happier driving the RTi's with the H/K over that Yammy.
    Mike
  • cmy330go
    cmy330go Posts: 2,341
    It won't add much more volume, but the added current from the HK should tighten up the lowend.
    Also the HK is likely to be a little warmer sounding than the Yamaha, which IMO is a good thing for the RTi8s.
    Go for it.
    Keep us posted.
    HT
    Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
    2 CH
    Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500,
  • pblanc
    pblanc Posts: 261
    One thing I can say with absolute certainty: 35 watts going to your main speakers from your receiver only is going to sound WAY better than 0 watts going to your speakers (unless you are listening to gangsta rap).
  • TroyD
    TroyD Posts: 13,124
    To achieve a 3db increase in volume, you have to double the amount of power.....
    BDT
  • cfrizz
    cfrizz Posts: 13,415
    Oh for crying out loud Troy!:mad: So how much power should he be looking to get???:o ;):D
    BDT
  • hoosier21
    hoosier21 Posts: 4,420
    wtf, he was making the point that 30 watts may go unnoticed
    chill
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • cfrizz
    I know the point he was trying to make Russ, but it still doesn't answer the question of how much power he should be looking to get to make a real difference.
    Put it in WPC so that he gets his question answered. I know you techies don't think much of WPC, but that is all they talk about in the B&M stores & most vendor websites.
    It is also how he phrased the question, so he should be answered in kind.
  • cfrizz
    PF1, if your receiver has preouts get a separate amplifier in the 200wpc catagory. You can get the best bang for your buck by getting used.
    If not, then update your receiver first making sure it has preouts & then later down the line get a separate amp.
  • TroyD
    TroyD Posts: 13,124
    I was merely making a point that many seem to miss. 30wpc either way is negligible (which I thought my statement made obvious)
    As far as how much power is needed? Hell, I dunno. Too many variables. Room size, listening tastes etc etc.
    Moreover, most people are going to disagree but I contend that a good 50wpc with 2db of headroom is MORE than sufficient for nearly all applications. However, everyone else seems to be on the big power bandwagon. Whatever floats your boat.
    BDT
