mono block
livewire
livewire Posts: 26
edited February 2007 in Electronics
I'm sorry but i don't undrestand when they say an amp is described a"mono block" is that a lesser quality of sound than from like a 7 channel amp or does it describe it as a one channel amp
Post edited by livewire on
  • McLoki
    McLoki Posts: 5,231
    It is just a one channel amp. It has really no bearing on its sound quality. (although it does have a few less limitations)
    Michael
  • Systems
    Systems Posts: 14,873
    A mono block means that it is a single channel in one chassis.This is beneficial because there is only one channel sourcing its current from the power supply.Generally the most powerful and expensive amps are mono blocks. for example http://www.bryston.ca/BrystonSite05/pdfs/28BSST.pdf
    Testing
    Testing
    Testing
  • livewire
    livewire Posts: 26
    so a dual mono block has 2 seperate amps for each of the two channels. i found a b&k amp for sale by me and that is what it is its ingreat shape my only question is it was bought new in 94' is that really even a factor
  • Systems
    dual mono block =2 chassis each with one channel for a total of 2 channels.
    Testing
    Testing
    Testing
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    A dual mono block should be 2 separate amps in one chassis, and should have 2 power cords also IMO.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • dorokusai
    dorokusai Posts: 25,576
    That's correct but depends on the actual amplifier design. You can be dual mono and share power rails. It doesn't have to utilize dual power cords, seperate supply rails, in order to benefit from the original design principle.
    I'll take a couple devils tails out of an amplifier any day.
  • disneyjoe7
    Thanks it's a least a good indication of a decent design. ;)
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Systems
    I should clarify my answer above.
    Two (not Dual)Mono Blocks =2 chassis 1 channel each for a total of 2 channels.
    Dual Mono=2 channels two power supplies 1 chassis
    Testing
    Testing
    Testing
