New member
NJPOLKER
NJPOLKER Posts: 3,474
edited January 2010 in Vintage Speakers
I want to introduce myself to all of you. I am a new Club Polk member who just purchased a pair of SDA2b's with interconnect cable. After reading about the SDA's in the forums I decided I could not go wrong spending less than $200. on a pair. I currently have a pair of Monitor 10's with peerless tweeters which I bought around 1980 that were unused for 10 years but in great condition. Here is where I need some help. I have been away from the market for along time, and unsure of what I need/should have to enjoy these speakers and future updates. I am sure I am on the right path and don't want to screw up now. My current receiver is a Denon DRA375RD which is rated at 60 wpc @ 8ohms, .05thd and I was told by Denon that it is a common ground receiver. I also have a Polk PSW 140 Subwoofer. The CD player is a Denon DCM-360.
OK here we go!
I know I need to upgrade the receiver and need suggestions. I'd like to spend around $400. to $500 on a receiver.
Can I use this receiver for now?
What should I do with the Monitor 10's?
Is the subwoofer OK?
If using the 10's are an option as rear speakers what center channel will be a good fit?
On a personal note; I work at a golf course here in New Jersey that is owned by Donald Trump which is closed till March so I have some time on my hands. So this is one of the things I am doing in the off season. I have a wife and two children and they currently think I listen to music too loud especially when I get a budweiser buzz on. God only knows what the future holds. Thanks in advance for your advice.
Drew R. Crawford the NJPOLKER
Post edited by NJPOLKER on
  • BobMcG
    BobMcG Posts: 1,585
    edited February 2007
    Welcome to CP!
    The 2Bs will make good fronts and the 10Bs good rears for you. Polk used to have a spot on their site that gave recommendations for matching the older speakers to a center speaker but I haven't looked for it in sometime. I do remember a few they said were OK to use in general, CS350; CS400; CS400i. Used ones are only available now but for good prices. I'm sure there are others with more to suggest.
    Your rcvr will be OK for now but don't expect too much performance out of the 2Bs with it. Not owning a rcvr in 25yrs+ I'm not into them or up on them and so not giving you recommendations on them. Plenty of others in here will cover that subject.
  • rcs
    rcs Posts: 21
    Here's the chart that matches Polk's center channels speaks to the vintage products:
    http://www.polkaudio.com/education/showanswer.php?question_num=63
    Primary: SDA-SRS 2 (front), CS-350LS (center), RT35i (sides)
    Secondary: RT-16
    Fondly remembered: SDA-1Bs (1987-1991)
  • Ern Dog
    Ern Dog Posts: 2,237
    Welcome aboard.
  • ben62670
    ben62670 Posts: 15,969
    does your Denon have pre outs?
    Welcome to Club Polk
    Ben
    Ben
  • hearingimpared
    hearingimpared Posts: 21,136
    Welcome to Club Polk. . .I don't know, SDAs need a good bit of power to make them sing. I have a pair of SRS 1.2 TLs being bi-amped horizontally with two Adcom 565 mono blocks @ 300 wpc. I also have a CRS which I've never hooked up yet but have been advised to use no less than 200 wpc, so I would think the same would apply to your 2Bs. There is plenty of information on this site on SDAs. Use your search. Also if you really want to know about SDAs, you should consider purchasing Darqueknights SDA Compendium 2nd Edition. Click this link for more information.
  • BobMcG
    BobMcG Posts: 1,585
    Yes, this is an updated list of matches for the older Polk's.
    I was trying to go by memory of an earlier list they had made which used a generation ago line up of centers that would probably be just a hair closer in age (yup, just a hair) and going used by now for very reasonable prices.
  • NJPOLKER
    Ben
    There are no pre outs on my receiver. I am going to purchase a new receiver soon. Maybe I should look into utilizing amp and pre-amp instead of a receiver.
  • NJPOLKER
    Thanks Bob, I am going to purchase the CSi5 center after I decide soon on the power plant. Thanks again
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    I would go the separates route if you can afford it. What is the price range you are looking to stay in?
  • NJPOLKER
    I am looking to spend maybe $500 to $800 on power. Thanks
  • Refefer
    Refefer Posts: 1,280
    Power and Preamp and Processor? Or just the power? For two channel or surround sound? 5.1, 6.1, or 7.1?
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • NJPOLKER
    Well I am finally taking alittle ride to pick up the 2b's Sunday morning. I am thinking that I should purchase a 5.1 or 7.1 common ground receiver in the area of 100 wpc and run an amp through the pre-outs. Am I on the right track? I really need some suggestions. Do you think around $500 on a receiver and another $500 on an amp would do the trick? Or should I spend the $1000 a different way? I have my Monitor 10's for rears and the psw140 sub so the CSi5 will come after the power I guess. Thanks in advance for your help the njpolker
  • NJPOLKER
    Lasareath wrote:
    Hello & Welcome NJPOLKER!, I'm From NJ too :)
    This Onkyo is a really nice 7.1 surround reciever, I have the same one but it's two years old. Lots of power, great features.
    http://cgi.ebay.com/Onkyo-TX-SR804-7-1-channel-Receiver-New_W0QQitemZ190082253806QQihZ009QQcategoryZ39797QQrdZ1QQcmdZViewItem
    Lasareath
    Where in new jersey are you from? I am from Hunterdon County. Thanks for the advice on the receiver and I am sure I will have more questions. Here is one now! Should I use the monitor 10's for rear speakers or should I not contaminate the SDA's sound? If that makes sence.
  • ben62670
    Look for an HK with pre outs. I am using an AVR-235 with adcom amps. I would concentrate on getting a good amp for the SDA's. They are 6ohms and take up to 350 watts. you really should look for an AMP that puts out 200 watts at 8 ohms. I'm partial to Adcom, especially the GFA-555 for SDA's. The HK AVR 235,240,245 are excellent receivers for use as a PreAmp. You could Also look for an Adcom 7500 that puts out 200 watts at 6 ohms which would definitely do you justice on the 5.1 system.
    Ebay link for HK direct
    http://myworld.ebay.com/harmanaudio/
    Good luck and happy hunting
    Ben
  • ben62670
    Lasareath wrote:
    Ben,
    What do you think about Sunfire Amps?
    Like the: http://www.sunfire.com/TGA7400.html
    Since I just got the SDA 1C's, I was thinking I should get a beefer AMP.
    Lasareath
    I would look to getting a little more power than what that model puts out:rolleyes: :D
    Ben
  • hearingimpared
    Lasareath wrote:
    You're correct, Why should I limit myself to only 400Watts per channel!
    I think I will get (5) of these: http://www.bryston.ca/28bsst_m.html
    1 per each speaker.
    1000Watts by 5, that should break my lease!
    What are they going for? 1k wpc my dream amps.
  • hearingimpared
    Lasareath wrote:
    $6100.00 Each, I'm sure if I buy 5 I can get a better price ;)
    Count me in maybe we will get the looney tune discount!!!
  • NJPOLKER
    I just pulled one of the drivers and on the back it says MW 6510 which means they are 2a's and the innerconnects are blade blade. Am I correct in thinking this and does it really matter which model they are?
    Thanks again
  • sd_speaker
    sd_speaker Posts: 38
    edited January 2010
    NJPOLKER wrote: »
    OK here we go!
    Hi Drew
  • NJPOLKER
    edited January 2010
    This thread sure brings back some memories. My system sure has come a long long way.
    What the was I thinking about back then?? Embarrassing that I was even considering something other than a two channel system.
  • WastelandWand'r
    WastelandWand'r Posts: 466
    edited January 2010
    I started reading this thread and got really confused. I could have swore that NJPOLKER had been around here for a while and couldn't figure if you were writing this for someone else or that maybe you had taken the red pill instead of the blue one.
    The next reply was as if someone was playing along, at that point I got really sideways. I figured it must have been a slow day in NJ and we all wanted to do some type of flashback thing.
    Then it came to me to look at the date!!!
    You guys trying to pick on us slow ones??
    Nathan
    Home Rig
    SDA 2.3TL's front and center
    Polk 1000p Center
    Pioneer Elite SC35 Receiver (Pre/Surround
    Sunfire Cinema Grand 5X200-Back in the mix.
    OPPO BDP-93
    Squeezebox
    Stepped up to name brand Speaker Cables and interconnects!
    Monitor 4, 5, 7, 10's, SDA 1B's, 2B's, 2.3TL's, RTA 15TL's all in storage waiting for me.
    Sales Rating #1!!
  • hearingimpared
    edited January 2010
    Nathan
    Nope just some troll stirring up the place.
