Newbie Amp Questions??
azfabshop
azfabshop Posts: 18
edited February 2007 in Electronics
Hello everyone! I have just taken my first hit of the HT crackpipe and I'm hooked! I have a few questions about the new system I am setting up in my sig below. I wanted to do the Mo Power thing and got a super deal on a pro amp I couldn't pass up.It's a Crown CP660 75w X 6 and brigeable. I was thinking of running it at 150x3 on the fronts and center and running the rear thru the HK. First is this a good, usable amp for my setup? It says its can be for HT use. It was being used to run a setup in a coffeeshop for music. Is the fan going to be too loud, it says variable speed to meet cooling needs? Next the inputs are "three-terminal barrier block balanced connectors" how do you connect that at one end to my RCA preout on the HK. Or am I better off with a different amp. I'm trying not to throw down any more cash till I recover from this and I need my rear surrounds first but I could sell this amp and use the$ on another. Thanks for the help!!
Harmon Kardon AVR 245 set 5.1
Polk CSi5- center
Polk RTi6- fronts
SVS PCi 22-31- sub
Polk FXi3- surrounds
Mitsubishi 65" DLP 1080i
Denon 1930Ci DVD
Playstation 3
Post edited by azfabshop on
  • azfabshop
    azfabshop Posts: 18
    Has anyone even heard of a Crown CP660 or have any thoughts on this?
    Polk CSi5- center
    Polk RTi6- fronts
    SVS PCi 22-31- sub
    Denon 1930Ci DVD
    Playstation 3
    F1nut Posts: 51,997
    I don't know about that amp, but Pro amps in general aren't highly regarded for home use. They are designed to deliver power, not sound quality. YMMV.
  • snow
    snow Posts: 4,358
    Agreed . Most pro amps are designed for power and stamina not discerning ears. It has been my experience that most of them dont sound very musical. Kind of harsh to my ears actually and unrefined. I did have one amp that sounded great as a home amp even though it was designed as a pro amp. The ALTEC-9440A a 2 channel amp. I also owned the ALTEC 9444A a 2 channel amp and it sounded awful to me. Since you have it you are the one that has to be happy with it. so try to compare to a couple other amps if you can, have your buddys bring theres over to compare to give you some idea. btw you can go to your local pro music shop and buy the adapters you need to convert from the balanced ins on the amp to the rca preouts on your reciever. REGARDS SNOW
  • azfabshop
    azfabshop Posts: 18
    Thanks forthe help. I'm not finding much on this amp online "which should tell me something" It was used to run the audio system in a coffee shop and the Crown website states it can be used for HT. I got a smokin deal on it but I may just sell it and find one more suited to my needs. I just watched one sell on Ebay for 500. with 27 bids so some one must like them!
    Polk CSi5- center
    Polk RTi6- fronts
    SVS PCi 22-31- sub
    Denon 1930Ci DVD
    Playstation 3
  • hearingimpared
    hearingimpared Posts: 21,136
    Can't help you there but Welcome to Club Polk!
  • snow
    snow Posts: 4,358
    That doesnt surprise me on the price. I believe it was a $1300.00 or so amp new and its not very old. And crown is a respected name in pro audio. If you can sell it for $500.00 then i would look for something like a marantz MM9000 amp its 150wpc X 5 and can be had in the 500- 700 range on ebay. Or some similar amp. REGARDS SNOW
