What brand would you buy??
dholmes
I have appx 4000-5000 $ to spend on a pre-amp & amp, what would be the best choice?? thanks
My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Post edited by dholmes on
2 ch or HT 5-7 ch?Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
And what speakers will you be using?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
7 ch, Polks RTI 150 & csi40 & fx 1000 surrMy HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
dholmes wrote:I have appx 4000-5000 $ to spend on a pre-amp & amp, what would be the best choice?? thanks
Head straight for this site. http://www.avahifi.com/ There's no need to spend that much money to get superb gear. Frank's gear is top notch in both sound quality & build quality. It's next to impossible to find any of his gear on the used market because owners never feel the need to upgrage & it's built so damn well it just seems to last forever. Happy hunting! I've got Frank's OmegaStar 440EX amp & Ultra DAC. Both pieces are here for the long haul in my system. Their performance/price ratio is second to none."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
Hell, you already have a great pre/pro and fantastic amps. Not sure you'd gain much at all by spending $5K to "upgrade" your amp and pre, and keeping the same speakers which, IMO, are the weakest link in your setup.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I agree with early b, you should upgrade your speakers instead. For that price you could get a killer system.58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub -
Well let me tell you all the sad story. I sold my Ati amps & my Sherwood & got Adcom 7807 & Adcom gtp-870hd pre-pro. Well the 7807 didnt work, sent it back NO 7807 available till April so I got 2 7805 amps & guess what they are busted Ive got no luck!!! The 7807 when I turned it on it just clicked & clicked & then buzzz, the 2 7805 did the same thing!! Its not my electric, had it checked,its not the balanced or rca innterconn, it does the click & buzz with nothing pluged in but spks. I bought everything from Onecall so I can ship it back!My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
agreed, speakers are the weak link. 4-5 grand on electronics is over the top for the RTi series.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
Now that is sad, you sold working equipment to make at best a lateral move to get equipment that doesn't work!
Perfect example why upgrading for the sake of trying something new is NOT always a good idea.
Hope you have better luck with whatever you end up with DH!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
+1 for the upgrade speakers route.
Thanks, I got the upgrade bug & thought I was doing good! Would the Outlaw 990 & the big amp they have be a good choice with my spks?My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
On my RTi speakers, the Outlaw gear sounds absolutely amazing. I just went to seperates end of 2006 so I don't really have alot of experience with other seperates but in my opinion, you can't go wrong with Outlaw's bang for the buck components.Money Talks, Mine says Goodbye Rob!!!!
Thanks Im trying to contact Outlaw now!! I looked at your HT Its AAA+++ I have the svs sub the ultra plus how does 2 svs sound?My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Well I just ordered the Outlaw 990 & 7700, hope its A+My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
Look into an Rotel RSP1068/RMB1077 combo, I had this replace my parasound hca's 1200's and 2200. Pretty happy with the results but requires some 'break in' time.
D-class amp, small, light and easy to move around. :PGear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
Conditioner: Isotek -
Ferres wrote:D-class amp, small, light and easy to move around. :P
Your won't get the light and easy to move around with the 7700, darn near 100lbs. if I'm correct.:DMoney Talks, Mine says Goodbye Rob!!!! -
Thats not a problem, I moved the 7807 which was 120 lbs & the 7805 x2 are 88 lbs with no help, strong back weak mind!!My HT set-up Panasonic front proj, 120 in ws screen, ATI amp,Integra 9.8 pre-pro, 2 Polk rti150, cp 1000, 4 fx 1000, Pioneer blu-ray 2 SVS sub pb 12-ultra 2, & Paragon popcorn popper. ps 3 Coaster leather HT recliners.
:eek: :eek: :eek: I'm reaching for the ibuprofen even as I type!:eek:
You are going to LOVE the Outlaw combo. You are going to think you have a whole new set of speakers!!!
CONGRATS!:)dholmes wrote:Thats not a problem, I moved the 7807 which was 120 lbs & the 7805 x2 are 88 lbs with no help, strong back weak mind!!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
dholmes wrote:Well I just ordered the Outlaw 990 & 7700, hope its A+
I'd be surprised if the Outlaw gear will sound significantly better than what you already had (ATI/Sherwood combo). I hope I'm wrong, though.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
From what I have read, the Outlaw pre is a rebadged Sherwood, and Outlaw amps are made by ATI. I wouldn't expect it to sound much different than the old setup.
