Best Wire (Again)
Sansui
Which is the best wire to use for hook ups? Solid conductor, stranded and twisted tightly at hook up terminals, or stranded and tightly twisted with ends soldered at hook up terminals?
Which wire ends are best to use without using banana plugs or spade lugs? Which wire iends are best to use with banana plugs and which is best to use with spade lugs.
I'm just curious seeing as how with every connection (and/or splice) in a wire run (between the two connections) has the possibility of degradtion of conductance or signal.
Be gentle, I'm new to all this...
The mind blowing speed of the BRAIN TRAIN...
Post edited by Sansui on
Im using 2-pair of Knukonceptz 10ga (bi-amp)with single bannana plugs. stranded copper and twisted slightly. Then use a conductor enhancer or dielectric grease to ward off corrosion. and tighten the connection up with the screwdriver....and play loudly
but thats just me there are alot of good wires out there ......:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
the kind I`m using...!!!Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool:
