vinyl to CD using Mac?
Jim Shearer
Jim Shearer Posts: 369
edited February 2007 in 2 Channel Audio
It's time to get a new computer--my nasty old PC (running Win 98SE) has to go.:p
My daughter and brother are both recommending I buy an Apple Mac (NOT Mac mini.) I am in the middle of a long term project transferring old vinyl and tape to CDs. I see that there is a program called Toast 8 from Roxio that claims to have tools for doing vinyl to CD, but I am wondering:
1) Is the sound card in the Mac adequate to the task?
2) Is Toast 8 suitable for the job?
Thanks for your help!
Cheers, Jim
A day without music is like a day without food.
Post edited by Jim Shearer on
  • Refefer
    Refefer Posts: 1,280
    I'm not at all familiar with Toast 8, but as for the soundcard, you can certainly grab a USB/Firewire M-Audio soundcard for the mac that will be much better sonically from the mac's built-in soundcard.
    Honestly, Toast 8 probably does the trick fine. Just make sure you stay away from any sort of dynamic compression and you should be good.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • Jim Shearer
    Thanks. I'm feeling better & better about going w/ the Mac.
    Cheers, Jim
