I dont exactly know where to post this - this will do though.
VR3
VR3 Posts: 29,445
edited February 2007 in Speakers
This is really a multi subject thread. It involves electronics, speakers, subwoofers. Everything.
So, my system is mainly based on 2 channel music and for 2 channel music, it defiitely excels. I would say the biggest weakness is without a doubt Home Theater. It just isnt there.
Well the Odyssey Audio Candela has a HT Bypass, so I was thinking about getting a unit like an Outlaw preamp or Emotiva (I like the Emotiva better) and using some its features.
Here is the idea...
Basically, I will be running dual subs - and for music Ill have the crossovers set to where I want them, via the subs. And a I would run one cable to one of the inputs on each of the subs and that would go to the Odyssey.
Then I would go on the LFE out on the HT preamp and run it to the other inputs - and I would disable the crossovers before a movie and use a preset 80hz xover and boost the subs via the LFE level on the preamp to get the volume I want out of them, so basically all I would be doing is flipping two switches to get the performance I desire.
Any thoughts?
Another benefit to this is I can crossover my mains as well and can therefore crank it a lil louder.
Post edited by VR3 on
  • Serendipity
    Serendipity Posts: 6,975
    Good ideas. Only suggestion would be to run the subs directly to the HT preamp for movie use.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
