SurroundBar settings with Yamaha HTR 5935
beaglemg
beaglemg Posts: 4
edited February 2007 in Speakers
Hi All,
Just purchased the SurroundBar and have successfully connected to the Yamaha receiver after some issues with the fronts not playing. However, I am curious on how best to tweak the settings to take advantage of the receiver. As the receiver is new and everything is adjustable, I welcome your opinions on this.
The room is rectangular (15w x 20l) with the TV over the fireplace and surroundbar on the mantle. I opted for the alternative setup with the speakers small and yes to subwoofer. The crossover is set at 120. I had to set the audio delay to 80 to sync up with the tv. I certainly appreciate any more information or advice you can give me as I want to make sure this purchase will be satisfactory prior to the return period ending. I have attached the receiver manual for reference. Please be very specific to your advice as I understand very little about speaker setup.
Any modifications would be greatly appreciated prior to the Superbowl. None of my girl-friends are of any use.
