Speaker Cable Question (for LSi9's and LSiC)
resperc
resperc Posts: 41
edited February 2007 in Speakers
Fellow Polksters
I am going to purchase some new speaker cables in the near future (probably Signal Cable). I have a couple of quick questions that I hope you can answer...
1) What width of spade do I need for LSi9s and LSiC (1/4", 5/16", or 3/8")?
2) I have a Rotel RMB-1075 for amplification. Should I get the bi-wire option? Any perosnal experience with 9s and C bi-wired? Is it worth the extra $$$?
Thanks, repserc
Post edited by resperc on
  • SLOCOOKN
    SLOCOOKN Posts: 704
    I would go with nanners...easier to deal with. I use a good jumper and do not bi-wire. Bi-wire is a many splendid thing...some say yes and some say no...You will have to try it your self. Good cables though...clup polk get 5% off so mention this.
    :eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More" :D
    Sony cx985v (for now)
    BBE 482i
    B&K AVP 1030
    Adcom GFA 555 mk 2
    AudioQuest Crystal 2 spk wire
    Nordost RCA
    SDA 3.1 tl RD0 tweets
    Belkin pf60
    Carver TFM 55x
    Signal Analog 2 RCA
    AudioQuestType 4
    VMPS Original Tall Boy (Mega Woofers soon)
  • dane_peterson
    dane_peterson Posts: 1,903
    I requested spades on my Signal Cable wires, and they're not quite wide enough for the LSi terminals. I squeezed them on there, but you'd probably want a little bigger.
    I'm guessing mine are 1/4", but ask Frank. I'm sure he'll know what to get you.
  • pblanc
    pblanc Posts: 261
    For what it is worth, the solderless, screw on type Monster spades fit LSi posts very well, and remain securely attached to multistranded wire.
  • resperc
    resperc Posts: 41
    Thanks for the info. resperc
