Monitor 50 Vs Rti4
Paramount Polk
Hello, i am considering the Monitor 50 in replacement for my Rti4's for my Pc 2.1.
I couldnt get it all by myself. so i'd like to ask you guys~
What are the advantages of the Monitor 50 over the Rti4?
So far i know its bass response and sensitivity?
But what about the tweeter? will i still get the clear, smooth, highs? are they the same Vifa tweet?
The Rti4 has the Power Port and ARC ports. i especially Love the ARC port. the mids are exactly what they say it is. Natural. not too strong, not too weak. Just the perfect amount for me.
I've never heard the Monitor 50 before.
What can you add to the M50 for me?
Receiver- Onkyo TX-SR304S
Speakers- Front-Polk Rti4
Rear- Bose 161
Center- Bose Cubes
Subwoofer- composed of
-PIONEER TS-W251R 10" SUBWOOFER
-Dayton 1.0 CU FT SUBWOOFER CABINET
-DAYTON SA240-B 240W Sub Plate Amp
Desktop
-AMD Athlon 3000+ 1.8Ghz
- Geforce 6600
- 512mb Ram upgrading soon...
- 80 Gig HD 160 Gig Slave HD
- ECS Nforce-A939 Motherboard
Rear- Bose 161
Center- Bose Cubes
Desktop
- Geforce 6600
Post edited by Paramount Polk on
Go to a store (like circuit city) and listen to them... thats the best advice anyone can give you.AVR: H/K AVR240
Fronts: Monitor 50s
Center: CSI3
surrounds: R15s
Sub:Velodyne DPS10
Dvd/Cd: Samsung HD upconverter (for now)
TV: 50" Sammy Plasma
game hardware: 360 and gcn.
Gamertag: kovster27 -
Funny how i tell people the same now i get it myself... but what have you to say for your own experience? i see from your sig you have a pair. I normally take the opinions of others first, audition then finalize my decision. weird?O.0Receiver- Onkyo TX-SR304S
Rear- Bose 161
Center- Bose Cubes
Desktop
- Geforce 6600
- ECS Nforce-A939 Motherboard -
What are your goals with this upgrade (more side- if not down-grade)?
The new Monitor is a very good speaker line, no question about it, but I would not replace the rti4 with a Monitor. Monitor 70 mmm maybe, but not the 50.
The specs of these 2 speakers are nearly identical, including the efficiency and bass extension; you really need to look at the +/- 3 dB numbers, and there only 3 Hz separate rit4 from Monitor 50.
To my ears highs and midrange sound better on RTi, too, and you already said how much you like the mids from your rti4. -
Regarding the Monitor 50's, I find them too warm in the lower midrange and not deep enough to justify such a (relative to the RTi4, at least) large enclosure. It might have been the carpeted listening room my folks have their 50's in, but I've also listened to the entire line in the stores, too, and this seems to hold (I did enjoy the 70's a bit).
I'd make a bigger jump if you're going to upgrade. Have you considered the RTi8's? Not much bigger than the 50's but much more compelling presence, IMO. And you could use the 4's for surrounds if you ever decided to go that way... -
^ +1
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
VSchneider wrote:What are your goals with this upgrade (more side- if not down-grade)?
My goal would to be getting a larger sound from my speakers, generally. with the extra woofer and larger port/enclosure i would expect it to have deeper fuller sound. more 3D?
yea, i already admire the sound of this lovely tweeter. and the great mids...McCelery wrote:Regarding the Monitor 50's, I find them too warm in the lower midrange and not deep enough to justify such a (relative to the RTi4, at least) large enclosure. It might have been the carpeted listening room my folks have their 50's in, but I've also listened to the entire line in the stores, too, and this seems to hold (I did enjoy the 70's a bit).
Ah, im trying to keep the cost to a minimal... my goal is simply tower speakers. though i'd love to have the same great sound. and yea, i'd love to have the Rti8. it looks absolutely fabulous.Receiver- Onkyo TX-SR304S
Rear- Bose 161
Center- Bose Cubes
Desktop
- Geforce 6600
Go with quality over quantity (or size). I had cheap towers (infinity entra three) and Rti4s. I chose to make the Rti4 my mains. They sounded better, not ness. louder. When I save up I will ge matching RTi8.Harman Kardon 245
Polk CSi30
Polk RTi6
Polk RTi4 (2)
Polk R150 (2)
Infinity Entra Three (2)
JBL PB10 Sub
JBL 500 (2)
