Emotiva
JimBRICK
JimBRICK Posts: 1,543
edited February 2007 in Electronics
http://www.emotiva.com/amplifiers.html
Anyone know anything about this company?
their ultra theatre series for 899 sounds to good to be true
that power and preamp
2 CHANNEL
Speaker - Klipsch Heresy II
Under construction
Post edited by JimBRICK on
  • jakelm
    jakelm Posts: 4,081
    That LPA-1 looks very attractive. With specs and price.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • joeparaski
    joeparaski Posts: 1,865
    I bought their Emotiva LMC-1 pre-pro last July through AVS123. There was a HDMI upgrade for it that was to be sent to LMC-1 owners free of charge. I had forgotten about it until last week. I then found out that AVS doesn't carry Emotiva anymore so I called Emotiva direct. Very nice folks to deal with, they didn't even want the proof of purchase and are sending me the upgrade free of charge.
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • jakelm
    jakelm Posts: 4,081
    I would be more interested in the amps..looking to upgrade to preout on my HK635
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • PolkThug
    PolkThug Posts: 7,532
    I want that IPS-1.
    What is "Class H design"?
  • McLoki
    McLoki Posts: 5,231
    It looks like the DMC-1 pre-amp is a rebadged Sunfire Theater Grand IV. If that is the case - it would be a heck of a deal for $1,499.
    Michael
  • Shizelbs
    Shizelbs Posts: 7,433
    I like in the article when the author say Emotiva chose to do this and Emotiva chose to do this and that, and ohh, Emotiva was smart to do this. No numbskull, Bob Carver was smart to do that, Emotiva was smart to not screw with the design. :rolleyes:
  • Early B.
    Early B. Posts: 7,900
    I got my eye on that RPA-1 amplifier. Could be a winner.
    "God grooves with tubes."
  • read-alot
    read-alot Posts: 812
    Yes that RPA sounds like a looker but dual mono and dual transformers don't sound to good for it being common ground or am I just paranoid?
    I have thought for awhile now that we need a (sticky) thread with known common ground amps for people coming here with SDAs looking for power.
    polkaudio SRS (rdo194 x 8)
    Dodd ELP (separate power supply)
    JC 1 blocks ( strapped )
    Rega Apollo
    MIT (speaker cables) Outlaw (ICs)
    polkaudio SDA2(rdo194x4) (front) polkaudio CRS (rdo194x4)(rear) polkaudio 400i (center)
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • unc2701
    unc2701 Posts: 3,587
    You're sorta being paranoid. Plenty of dual mono's are common ground- if you can bridge mono it, then it's common ground. Oh, wait, I was looking at the BPA. I dunno on the RPA.
    Backburner:Krell KAV-300i
  • Early B.
    E-mail Emotive with your question. I had a technical question, so I e-mailed them earlier today. They responded within a couple of hours with the answer I was looking for.
  • jakelm
    jakelm Posts: 4,081
    Now if I'm reading correctly these amps are just amps right? No processing board or any type of matrixing going on inside the amp. Seperate 7 amps into 1.
    I wonder what type of upgrade that LPA-1 amp would give me over the built in amps on the HK635
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • McLoki
    McLoki Posts: 5,231
    Based on this review (and a few others I have read) they may have - or have had some quality issues going on with their pre-amps. They do have a decent warrantee so maybe you will be taken care of.
    Just wanted you to be aware of it.
    Michael
  • jakelm
    jakelm Posts: 4,081
    I might just try this one out.
    http://www.emotiva.com/lpa1.html
    With a 30 return policy, you cant go wrong.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • read-alot
    I did yesterday.
    No reply yet.
    Maybe they have to ask someone in China.
    I'll probably go with the A21 anyway.
    Rega Apollo
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
  • bknauss
    bknauss Posts: 1,441
    PolkThug wrote:
    I want that IPS-1.
    Class G and Class H refer to having whatever amplifier class you want (generally AB), but the voltage rails supplying the power will switch based on the music signal. If the music is low, there's a lower voltage rail used, and therefore less power consumed. Class G has seperate hard rails that can be switched between while Class H has rails that will dynamically change with the music signal. Basically, its a AB amp (generally) with much better efficiency.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • read-alot
    I'm thinking they don't know the answer or they don't care that I know.
    It's been a few working days and no reply. Oh well there was a slim chance that I would try their stuff anyway.
    Rega Apollo
    B&K 505
    Samsung LCD
    VIP 622
    HSU STF-2
