wattage
thegoat191
what is the maximum wattage that i can supply to my MM455's and MM400's?? i'm very new to the whole car audio scene, so basic lingo would be appriciated. what is the difference between RMS and maximum?? thanks
Post edited by thegoat191 on
i have the momo component set in the back (MM455 and MM400) using a crossover, and another component set in the front, also using a crossover. the amplifier i have purchased delivers 250 per channel (4 ch). therefore it will be around 125 a speaker, right? this is adequate?
